Move System Dataset SCALE
MikeLowry
Hi All,
Need to move the system dataset to the boot pool due to noisy reads every few seconds. I don't see that menu option on SCALE RC2.
The NAS is not in production yet so I also need to resize the pool (and create 2 pools on 3TB each - any recommendations appreciated.
Cheers
M
It's not done through the Storage menu, but through the System menu.
I wonder if you need to reboot for it to fully take effect in SCALE?
Try rebooting and double-check that the syslog and .system dataset resides on the boot pool.
zfs list -t filesystem | grep -F ".system"
HarryMuscle
Not runnings any apps yet - still a fresh install. It's on a QNAP TS-470 Pro with a 1TB Samsung SSD as boot drive.
In your screenshot I see the ix-applications dataset already exists so I wonder if Kubernetes writes to it even without any apps being installed. Not sure if it's possible to move that dataset to an SSD for you but I would try that and see if the hard drives stop being accessed.
Thanks,
Harry
MikeLowry
Hi @winnielinnie ,
Rebooted and confirmed that the system is now on the boot pool.
The drives are still accessed every 5 seconds:
@HarryMuscle - I don't see an option to move IX-Apps to another pool
Cheers
M
MikeLowry
Hi @winnielinnie ,
Cheers
M
Hi All,
The drive access is related to ZFS.
To resolve the 5 seconds drive access, I followed this blog article:
NewsPaint Blog
Want to Slow Linux ZFS Flushing/Syncing to Disk Every 5 Seconds?​
Leave a comment Posted by newspaint on 2016-08-07
So you’ve got ZFS on Linux and you notice your hard drive LED light up every 5 seconds. How can you slow that down?
The zfs_txg_timeout parameter is described as:
~# modinfo zfs |grep zfs_txg_timeout
parm: zfs_txg_timeout:Max seconds worth of delta per txg (int)
You can check the current value of this parameter:
~# cat /sys/module/zfs/parameters/zfs_txg_timeout
5
To verify this is the parameter you want to change, set this to 10 and count the number of seconds between the hard drive light coming on:
~# echo 10 >/sys/module/zfs/parameters/zfs_txg_timeout
Once you know this is the parameter causing the hard drive activity you can tell the ZFS module the default you want it to start with on next boot by editing /etc/modprobe.d/zfs.conf and adding a line similar to the following:
options zfs zfs_txg_timeout=30
Take care when changing this number as it may result in a higher probability of lost data in the event of a power outage.
Tested the options via SSH but I did not edit the /etc/modprobe.d/zfs.conf as this won't form part of the TRUENAS backup. I created a POST INIT command to set this option.
