mountroot issues
felipe3471
Hello, I had an issue yesterday with version 9.10., I was migrating some virtual machines to FreeNAS storage and all of a sudden it became unresponsive and restarted itself.
After it restarted, it now hangs on mountroot. It fails to load even other snapshots.
I attached a screenshot of the error at the top of the shot.
Any assistance would be fantastic as I have customer servers on that NAS.
Thanks!
Sakuru
My guess is that your boot drive failed. Do you have a config backup?
felipe3471
boot device is raid1, do you think both disks went bad?
i do NOT have a config backup. possible to extract from bad disk? if it lets me.
worst case, if i do a fresh install on a usb stick, would i be able to import the existing volumes that are there?
thanks for the reply
Sakuru
felipe3471
hardward RAID, which was basically done from dell perc controller. would that make a difference?
nojohnny101
What do you have for your boot disks? USB drives or SSD?
Config backup is one of the foundational things to safeguarding your system from failures. If you reinstall then your data will be safe but all of your settings regarding users, shares, network settings, etc. will be reset.
felipe3471
SSD drives.
i wouldnt mind configuring the network settings, etc but will i be able to load the volume drives with the virtual machines on it?
would i be able to extract the config db from the old drives if i create a new bootable?
felipe3471
now it seems to be going through a difference sequence "port 1 power on or off failed, USB_ERR_TIMEOUT"
wblock
Documentation Engineer
What do you have plugged into the USB ports? An external hard drive, maybe?
felipe3471
i had an external cd rom. i unplugged and back at the mountroot> screen
what do you recommend next steps are?
felipe3471
System specs:
DELL POWEREDGE R730xd
Processor Intel(R) Xeon(R) CPU
Memory 65GB
6 x 200gb SSD
6 x 1.2 TB 10k SAS
11 x 600gb 15k SAS
Sakuru
Maybe. I was unable to help that person, but maybe your config backups actually exist.
felipe3471
i was able to boot with live cd and go to shell.
i able to navigate to data folder and i see the freenas-v1.db
what is the command to export the db to another flash drive ? or how would i extract it?
thanks, i feel like ive made some progress here.
Sakuru
Just copy that file to your other flash drive.
felipe3471
yes, thats what ive been trying to do but need help with mounting the USB and the command to copy the file over.
Sakuru
Sakuru
Plug in your flashdrive and find its drive letter with camcontrol devlist. Create a folder and try to mount your flashdrive.
mkdir /mnt/flashdrive
mount /dev/da1 /mnt/flashdrive
If that works you can copy your database with the cp command.
cp /where/you/found/it/freenas-v1.db /mnt/flashdrive/
