Hello
I have FreeNAS 9.1.1 at the moment installed in my virtual environment based on ESXi 5.1 with passthrough 6 drives - 5x2tb and 1x3tb. I wanted to create raidz2 pool but because of different size disks i couldn't do that bu gui. So i did it by hand. Pool created successfully(i used zpool with -f)
Then i found that id didn't shows on the gui. I looked on the web and did import.Import went succesfuly and i have access to the pool. Unfortunately everytime when i restart system there is a problem with mountpoint. - there is no folder in /mnt/... that should be related to the pool.
That problem was not exist when i created pool from gui. what needs to be done to keep that pool after restart ?
Thanks in advance.
Thanks in advance.
