During the process of helping someone rename their pool, I discovered you can't export a pool containing datasets from the GUI or the command line. From the GUI I get 'The Volume Failed To Export', and from the command line I get something like mountpoint in use. What I realized is that each dataset is a sub-mountpoint of the main pool, so that explains the 'in use' error at the command line. What I also discovered was that when I 'cd'd to the mountpoint/dataset all of my data appeared to be missing. After a slight panic, I did a reboot and datasets/data were ok.
So my question is, is there a proper way to export a pool with datasets or is it just not working correctly?![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I'm using 8.01 beta-4, AMD64, raidz2, with 9 datasets.
