Hi, need some input whether this is safe and a viable option.
I am currently doing my first FreeNAS build for myself which is a 4 drive setup in a node 304, the PSU im using for this build is a Seasonic SS-350ET 350W. The issue I'm having is the SATA power cables won't reach the the hdd's as the cables arent long enough, but when I mount the PSU upside down the cables reach fine. Thing is now the PSU's fan is facing the hdd's and also the PSU is about 1mm to low to reach a mount screw which secures the PSU into place (was thinking of using a thin sheet of plastic under the PSU to fix that issue).
Would prefer to do this rather then shell out more £ for another PSU.
Thanks
Thanks
