Clinderw
- Aug 11, 2013
Hello All,
I want to mount two parts of my pool to linux. I have successfully created mount points for both, one is a folder i created on the pool and one is a data set.
The folder on the pool mounts fine and i can see all the subfolders and files. The dataset mounts but i can't see any of the contents of the mount within linux.
Can anyone assist with why? After some searching it seems like it might be a permissions thing but i dont have the first clue about how to resolve that.
Thanks
Thanks
