Updated from 8.0.1-b4 to r7209.
Now mountd does not start. During boot it says something like "mountd not running, check /var/run/mountd.pid" on the console.
There is no /var/run/mountd.pid
I have disabled/enabled nfs in "control services" in the gui a couple of times, rebooted etc.
I updated to 7226 just in case there was a bug in 7209.
"nfsd: master (nfsd)" and "nfsd: server (nfsd)" are running.
(The one thing I did after updating to 7209 was to do a "replace" for a broken disk. Resilvering went ok. Don't know if mountd was running prior to doing the "replace", would not think so.)
Any ideas?
Any ideas?
