SOLVED Mount on top of another mount
Todd Vernick
I recently downgraded from Corral and I think there is a mount on top of another mount because I can't access the directory structure where all the data should be. I noticed this happened in Corral and I was able to umount the mount point and the data would show up again. Now when I do it it says the device is busy. I know the data is still there because the disk utilization is still higher than what is shown currently mounted. Any idea how to get this mount back?
D
dlavigne
Guest
What steps did you use to downgrade? Which build version are you running now (from System -> Information)?
Todd Vernick
So I just fixed it. One of my old jails had the same share mount point as the nfs mount point. The jail was mounting over the actual zfs mount. Soon as I stopped the jail and umounted the same mount point name, the zfs mount came back.
Jailer
Not strong, but bad
Sounds like a bad round of Portal.
