Greetings,
A company I do work for has a small (moderate?) size vSphere environment (3 hosts, 4 SANs, 200+ VMs).
The SANs they have in-use are:
However, the elephant in the room is the Equallogic - which does not support having two interfaces on separate subnets
. Therefore, to get redundant (and load-balanced) connections they have a third adapter on the ESXi hosts configured on Storage VLAN 1 (250), and it appears that MPIO is working for the Equallogic (load is distributed across both NICs on both ends).
Ideally as part of this network re-organization I'd like to simplify this setup (which feels dirty). Initial thoughts were to breakdown the separate VLANs/subnets so that the network is setup to support Equallogic's backwards way of doing things, and have FreeNAS work in a similar way.
This would mean:
My question I suppose is what would those of you in this community recommend for a clean setup, that supports MPIO for both the Equallogic and the FreeNAS SANs?
Thanks for any incites you're willing to provide!
Aaron
- Equallogic (PS4210)
- 3*FreeNAS (repurposed Dell PE 2950's)
- Storage VLAN 1 (250)
- Storage VLAN 2 (255)
This would mean:
- 1 - Storage VLAN 1 (250)
- Removing the current 2nd (or 3rd however you look at it) ESXi storage interface, so only 2 exist in the same VLAN/subnet.
- Setting up a second IP on the FreeNAS in the same subnet
Aaron
