mixed vdev capacities but 2 mirrors with the exact same disks
Herman Eggink
I am seeing an orange exclamation mark saying mixed vdev capacities but the pool has 2 mirrors each having 2 identical disks. Any idea? Can't recall having seen this pre-cobia but may have been.
Are you using any special vdevs?
Herman Eggink
Not that I know...
Patrick M. Hausen
What do the partition tables look like? IIRC lsblk would be one way to get them in Linux.
Either it's a bug...
Or at one point you changed the default "swap partition size", which is triggering this (pointless) warning.
Herman Eggink
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
sda 8:0 0 7.3T 0 disk
├─sda1 8:1 0 2G 0 part
│ └─md126 9:126 0 2G 0 raid1
│ └─md126 253:0 0 2G 0 crypt [SWAP]
└─sda2 8:2 0 7.3T 0 part
sdb 8:16 0 7.3T 0 disk
├─sdb1 8:17 0 2G 0 part
│ └─md127 9:127 0 2G 0 raid1
│ └─md127 253:1 0 2G 0 crypt [SWAP]
└─sdb2 8:18 0 7.3T 0 part
sdc 8:32 0 7.3T 0 disk
├─sdc1 8:33 0 2G 0 part
└─sdc2 8:34 0 7.3T 0 part
sdd 8:48 0 7.3T 0 disk
├─sdd1 8:49 0 2G 0 part
└─sdd2 8:50 0 7.3T 0 part
sde 8:64 0 55.9G 0 disk
├─sde1 8:65 0 512K 0 part
└─sde2 8:66 0 55.9G 0 part
sdf 8:80 0 7.3T 0 disk
├─sdf1 8:81 0 2G 0 part
└─sdf2 8:82 0 7.3T 0 part
sdg 8:96 1 0B 0 disk
zd0 230:0 0 512G 0 disk
sda,b,c and d are my data disks for my pool Main
sdf is a single backup drive (same as all other disks) for a pool Backup
sde is a smaller boot SSD (55G)
sdg is listed as a Generic_STORAGE_DEVICE-0:0 of 0B (no idea how that ever got there but it's unused)
Herman Eggink
I can't recall ever changing swap. I did switch out all Red's for SSD's a while back (given that the system isn't very write active and the SSD's dropped quite a bit in price and I was upset with the noise and and and) but I didn't change swap AFAICT.
Patrick M. Hausen
All the data disks have the standard 2G swap partition. I'm out of ideas.
Can you run the lsblk command again, but this time pass the "-b" flag?
Herman Eggink
SD media card reader? :tongue:
Owww bugger, now why didn't I think of that...
Here's lsblk -b:
sda 8:0 0 8001563222016 0 disk
├─sda1 8:1 0 2147418624 0 part
│ └─md126 9:126 0 2145320960 0 raid1
│ └─md126 253:0 0 2145320960 0 crypt [SWAP]
└─sda2 8:2 0 7999415655936 0 part
sdb 8:16 0 8001563222016 0 disk
├─sdb1 8:17 0 2147418624 0 part
│ └─md127 9:127 0 2145320960 0 raid1
│ └─md127 253:1 0 2145320960 0 crypt [SWAP]
└─sdb2 8:18 0 7999415655936 0 part
sdc 8:32 0 8001563222016 0 disk
├─sdc1 8:33 0 2147418624 0 part
└─sdc2 8:34 0 7999415655936 0 part
sdd 8:48 0 8001563222016 0 disk
├─sdd1 8:49 0 2147418624 0 part
└─sdd2 8:50 0 7999415655936 0 part
sde 8:64 0 60022480896 0 disk
├─sde1 8:65 0 524288 0 part
└─sde2 8:66 0 60021915648 0 part
sdf 8:80 0 8001563222016 0 disk
├─sdf1 8:81 0 2147418624 0 part
└─sdf2 8:82 0 7999415655936 0 part
sdg 8:96 1 0 0 disk
zd0 230:0 0 549755813888 0 disk
What the heck is SCALE complaining about? Every single partition in your data vdevs are the same exact size, down to the very byte.
Surely this has to be a bug.
I managed to fix your problem. It's all about the color and the symbol!
But in seriousness, I'd file a bug report. (I could have sworn a similar issue happened before, which they supposedly "fixed" with an update?)
Herman Eggink
Will do. I thought I was going mad. Thanks for confirming and for the help.
