ghostrunner
- Jun 21, 2015
Originally my system was suffering from a degraded drive I removed one of the drives in the mirror and ran WD diagnostic test no problems detected turns out it was the good drive in the mirror. I took out the second drive in the mirror which was a Seagate drive ran a check and found that the drive did indeed have issues but I failed to detach the drive properly and received my v0 volume could not determine it's size. I ran both test using a USB SATAIII cable on a Windows system. My original motivation for doing these checks was to see if the bad drive could be fixed turns out this was a bad idea because now v0 can not detect any drives and worst yet I ended up detaching the whole v0 volume which I can not auto import now. Now I'm getting a message "ZFS-80006X" when typing "zpool import".
Is there anyway I can bring the system back to the degraded drive state? (i.e. Attache v0 back to a degraded state so I can properly resilver the drive)
I should mentioned that I had periodic system config backups but they resided on v0 which I can no longer import. I was thinking about importing the drive with the configs but I"m a little afraid to continue. I also think that running the diagnostics scans on the drives did something to the zfs table but I took a look on my Arch Linux system and it shows them as ZFS file systems. I also must mention that I tried running a repair on the faulty Seagate drive but this didn't work using Segates diagnostic software.
Here is some additional background information...
Current system specifications:
Thank you,
dmesg
zpool status -v
I've connected all the drives but I can't seem to get the system to recognize them.
This is what my "View Disks" tab looks like.
zpool import
Mobo: Gigabyte Micro ATX Motherboard GA-A75M-S2V
RAM: 16GB
CPU: AMD A4-3300 APU
SATAIII Card: IO Crest SATAII 4 Port PCI-e 2.0 x1
FreeNAS specifications:RAM: 16GB
Version: FreeNAS-9.2.1.8-RELEASE-x64 (e625626)
ZFS Volumes:
*Please note that I'm not exactly sure if the mirror naming convention was this before I had the problem.ZFS Volumes:
Volume name: v0
Volume name: v1
Num of drives: 6
Setup: Mirrored
Config:
v0
mirror-0*
Num of drives: 6
Setup: Mirrored
Config:
v0
mirror-0*
Seagate 3TB
Seagate 3TB
mirror-1*Seagate 3TB
Seagate 2TB
Seagate 2TB
mirror-2*Seagate 2TB
Seagate 3TB (Original degraded drive)
Western Digital 3TB
Western Digital 3TB
Volume name: v1
Setup: Striped
Num of drives: 1
Setup: Striped
Config:
v1
Setup: Striped
Num of drives: 1
Setup: Striped
Config:
v1
Seagate 1.5TB
Thank you,
dmesg
~# dmesg Copyright (c) 1992-2013 The FreeBSD Project. Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994 The Regents of the University of California. All rights reserved. FreeBSD is a registered trademark of The FreeBSD Foundation. FreeBSD 9.2-RELEASE-p12 #0 r262572+b043649: Sun Sep 28 23:03:31 PDT 2014 root@build3.ixsystems.com:/tank/home/jkh/build/921/freenas/os-base/amd64/fusion/jkh/921/freenas/FreeBSD/src/sys/FREENAS.amd64 amd64 gcc version 4.2.1 20070831 patched [FreeBSD] CPU: AMD A4-3300 APU with Radeon(tm) HD Graphics (2500.00-MHz K8-class CPU) Origin = "AuthenticAMD" Id = 0x300f10 Family = 0x12 Model = 0x1 Stepping = 0 Features=0x178bfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,MMX,FXSR,SSE,SSE2,HTT> Features2=0x802009<SSE3,MON,CX16,POPCNT> AMD Features=0xee500800<SYSCALL,NX,MMX+,FFXSR,Page1GB,RDTSCP,LM,3DNow!+,3DNow!> AMD Features2=0x37ff<LAHF,CMP,SVM,ExtAPIC,CR8,ABM,SSE4A,MAS,Prefetch,OSVW,IBS,SKINIT,WDT> TSC: P-state invariant, performance statistics real memory = 17179869184 (16384 MB) avail memory = 16002158592 (15260 MB) Event timer "LAPIC" quality 400 ACPI APIC Table: <GBT GBTUACPI> FreeBSD/SMP: Multiprocessor System Detected: 2 CPUs FreeBSD/SMP: 1 package(s) x 2 core(s) cpu0 (BSP): APIC ID: 0 cpu1 (AP): APIC ID: 1 WARNING: VIMAGE (virtualized network stack) is a highly experimental feature. ioapic0: Changing APIC ID to 2 ioapic0 <Version 2.1> irqs 0-23 on motherboard kbd1 at kbdmux0 cryptosoft0: <software crypto> on motherboard aesni0: No AESNI support. padlock0: No ACE support. acpi0: <GBT GBTUACPI> on motherboard acpi0: Power Button (fixed) acpi0: reservation of 0, a0000 (3) failed acpi0: reservation of 100000, cfca0000 (3) failed cpu0: <ACPI CPU> on acpi0 cpu1: <ACPI CPU> on acpi0 attimer0: <AT timer> port 0x40-0x43 on acpi0 Timecounter "i8254" frequency 1193182 Hz quality 0 Event timer "i8254" frequency 1193182 Hz quality 100 hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff irq 0,8 on acpi0 Timecounter "HPET" frequency 14318180 Hz quality 950 atrtc0: <AT realtime clock> port 0x70-0x73 on acpi0 Event timer "RTC" frequency 32768 Hz quality 0 Timecounter "ACPI-fast" frequency 3579545 Hz quality 900 acpi_timer0: <32-bit timer at 3.579545MHz> port 0x808-0x80b on acpi0 acpi_button0: <Power Button> on acpi0 pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0 pci0: <ACPI PCI bus> on pcib0 vgapci0: <VGA-compatible display> port 0xf800-0xf8ff mem 0xd0000000-0xdfffffff,0xfdfc0000-0xfdffffff irq 18 at device 1.0 on pci0 pcib1: <ACPI PCI-PCI bridge> irq 16 at device 4.0 on pci0 pci1: <ACPI PCI bus> on pcib1 re0: <RealTek 8168/8111 B/C/CP/D/DP/E/F/G PCIe Gigabit Ethernet> port 0xde00-0xdeff mem 0xfddff000-0xfddfffff,0xfddf8000-0xfddfbfff irq 16 at device 0.0 on pci1 re0: Using 1 MSI-X message re0: turning off MSI enable bit. re0: Chip rev. 0x2c800000 re0: MAC rev. 0x00100000 miibus0: <MII bus> on re0 rgephy0: <RTL8169S/8110S/8211 1000BASE-T media interface> PHY 1 on miibus0 rgephy0: none, 10baseT, 10baseT-FDX, 10baseT-FDX-flow, 100baseTX, 100baseTX-FDX, 100baseTX-FDX-flow, 1000baseT, 1000baseT-master, 1000baseT-FDX, 1000baseT-FDX-master, 1000baseT-FDX-flow, 1000baseT-FDX-flow-master, auto, auto-flow re0: Ethernet address: 50:e5:49:cd:85:52 pcib2: <ACPI PCI-PCI bridge> irq 17 at device 5.0 on pci0 pci2: <ACPI PCI bus> on pcib2 ahci0: <Marvell 88SE9215 AHCI SATA controller> port 0xef00-0xef07,0xee00-0xee03,0xed00-0xed07,0xec00-0xec03,0xeb00-0xeb1f mem 0xfdcff000-0xfdcff7ff irq 17 at device 0.0 on pci2 ahci0: AHCI v1.00 with 4 6Gbps ports, Port Multiplier supported with FBS ahcich0: <AHCI channel> at channel 0 on ahci0 ahcich1: <AHCI channel> at channel 1 on ahci0 ahcich2: <AHCI channel> at channel 2 on ahci0 ahcich3: <AHCI channel> at channel 3 on ahci0 pci0: <serial bus, USB> at device 16.0 (no driver attached) pci0: <serial bus, USB> at device 16.1 (no driver attached) ahci1: <AMD Hudson-2 AHCI SATA controller> port 0xff00-0xff07,0xfe00-0xfe03,0xfd00-0xfd07,0xfc00-0xfc03,0xfb00-0xfb0f mem 0xfe02f000-0xfe02f7ff irq 19 at device 17.0 on pci0 ahci1: AHCI v1.30 with 6 6Gbps ports, Port Multiplier supported ahcich4: <AHCI channel> at channel 0 on ahci1 ahcich5: <AHCI channel> at channel 1 on ahci1 ahcich6: <AHCI channel> at channel 2 on ahci1 ahcich7: <AHCI channel> at channel 3 on ahci1 ahcich8: <AHCI channel> at channel 4 on ahci1 ahcich9: <AHCI channel> at channel 5 on ahci1 ohci0: <OHCI (generic) USB controller> mem 0xfe02e000-0xfe02efff irq 18 at device 18.0 on pci0 usbus0 on ohci0 ehci0: <EHCI (generic) USB 2.0 controller> mem 0xfe02d000-0xfe02d0ff irq 17 at device 18.2 on pci0 usbus1: EHCI version 1.0 usbus1 on ehci0 ohci1: <OHCI (generic) USB controller> mem 0xfe02c000-0xfe02cfff irq 18 at device 19.0 on pci0 usbus2 on ohci1 ehci1: <EHCI (generic) USB 2.0 controller> mem 0xfe02b000-0xfe02b0ff irq 17 at device 19.2 on pci0 usbus3: EHCI version 1.0 usbus3 on ehci1 pci0: <serial bus, SMBus> at device 20.0 (no driver attached) isab0: <PCI-ISA bridge> at device 20.3 on pci0 isa0: <ISA bus> on isab0 pcib3: <ACPI PCI-PCI bridge> at device 20.4 on pci0 pci3: <ACPI PCI bus> on pcib3 ohci2: <OHCI (generic) USB controller> mem 0xfe02a000-0xfe02afff irq 18 at device 20.5 on pci0 usbus4 on ohci2 uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0 orm0: <ISA Option ROM> at iomem 0xc0000-0xcefff on isa0 sc0: <System console> at flags 0x100 on isa0 sc0: VGA <16 virtual consoles, flags=0x300> vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0 atkbdc0: <Keyboard controller (i8042)> at port 0x60,0x64 on isa0 atkbd0: <AT Keyboard> irq 1 on atkbdc0 kbd0 at atkbd0 atkbd0: [GIANT-LOCKED] wbwd0: HEFRAS and EFER do not align: EFER 0x2e DevID 0xff DevRev 0xff CR26 0xff hwpstate0: <Cool`n'Quiet 2.0> on cpu0 Timecounters tick every 1.000 msec ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled DUMMYNET 0xfffffe0003e24100 with IPv6 initialized (100409) load_dn_sched dn_sched RR loaded load_dn_sched dn_sched WF2Q+ loaded load_dn_sched dn_sched FIFO loaded load_dn_sched dn_sched PRIO loaded load_dn_sched dn_sched QFQ loaded usbus0: 12Mbps Full Speed USB v1.0 usbus1: 480Mbps High Speed USB v2.0 usbus2: 12Mbps Full Speed USB v1.0 usbus3: 480Mbps High Speed USB v2.0 usbus4: 12Mbps Full Speed USB v1.0 ugen0.1: <AMD> at usbus0 uhub0: <AMD OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus0 ugen1.1: <AMD> at usbus1 uhub1: <AMD EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1 ugen2.1: <AMD> at usbus2 uhub2: <AMD OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus2 ugen3.1: <AMD> at usbus3 uhub3: <AMD EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus3 ugen4.1: <AMD> at usbus4 uhub4: <AMD OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus4 (aprobe5:ahcich9:0:0:0): SET_MULTI. ACB: c6 00 00 00 00 40 00 00 00 00 10 00 (aprobe5:ahcich9:0:0:0): CAM status: ATA Status Error (aprobe5:ahcich9:0:0:0): ATA status: 51 (DRDY SERV ERR), error: 04 (ABRT ) (aprobe5:ahcich9:0:0:0): RES: 51 04 00 00 00 40 00 00 00 10 00 (aprobe5:ahcich9:0:0:0): Retrying command (aprobe5:ahcich9:0:0:0): SET_MULTI. ACB: c6 00 00 00 00 40 00 00 00 00 10 00 (aprobe5:ahcich9:0:0:0): CAM status: ATA Status Error (aprobe5:ahcich9:0:0:0): ATA status: 51 (DRDY SERV ERR), error: 04 (ABRT ) (aprobe5:ahcich9:0:0:0): RES: 51 04 00 00 00 40 00 00 00 10 00 (aprobe5:ahcich9:0:0:0): Error 5, Retries exhausted ada0 at ahcich3 bus 0 scbus3 target 0 lun 0 ada0: <ST31500341AS CC1H> ATA-8 SATA 2.x device ada0: Serial Number 9VS1S7B1 ada0: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes) ada0: Command Queueing enabled ada0: 1430798MB (2930275055 512 byte sectors: 16H 63S/T 16383C) ada0: Previously was known as ad10 ada1 at ahcich4 bus 0 scbus4 target 0 lun 0 ada1: <ST2000DM001-9YN164 CC4H> ATA-8 SATA 3.x device ada1: Serial Number Z1E3YEL4 ada1: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes) ada1: Command Queueing enabled ada1: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C) ada1: quirks=0x1<4K> ada1: Previously was known as ad12 ada2 at ahcich5 bus 0 scbus5 target 0 lun 0 ada2: <ST2000DM001-9YN164 CC4H> ATA-8 SATA 3.x device ada2: Serial Number S1E0B385 ada2: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes) ada2: Command Queueing enabled ada2: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C) ada2: quirks=0x1<4K> ada2: Previously was known as ad14 ada3 at ahcich6 bus 0 scbus6 target 0 lun 0 ada3: <ST3000DM001-1CH166 CC49> ATA-9 SATA 3.x device ada3: Serial Number Z1F4D193 ada3: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes) ada3: Command Queueing enabled ada3: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C) ada3: quirks=0x1<4K> ada3: Previously was known as ad16 ada4 at ahcich8 bus 0 scbus8 target 0 lun 0 ada4: <WDC WD30EZRX-00D8PB0 80.00A80> ATA-9 SATA 3.x device ada4: Serial Number WD-WMC4N0909180 ada4: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes) ada4: Command Queueing enabled ada4: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C) ada4: quirks=0x1<4K> ada4: Previously was known as ad20 SMP: AP CPU #1 Launched! Timecounter "TSC-low" frequency 1250000679 Hz quality 800 uhub4: 2 ports with 2 removable, self powered uhub0: 5 ports with 5 removable, self powered uhub2: 5 ports with 5 removable, self powered GEOM: ada4: the secondary GPT header is not in the last LBA. GEOM_PART: integrity check failed (ada4, GPT) Root mount waiting for: usbus3 usbus1 uhub1: 5 ports with 5 removable, self powered uhub3: 5 ports with 5 removable, self powered Root mount waiting for: usbus3 ugen3.2: <hp> at usbus3 umass0: <hp v125w, class 0/0, rev 2.00/10.00, addr 2> on usbus3 umass0: SCSI over Bulk-Only; quirks = 0x0100 umass0:11:0:-1: Attached to scbus11 Trying to mount root from ufs:/dev/ufs/FreeNASs2a [ro]... mountroot: waiting for device /dev/ufs/FreeNASs2a ... da0 at umass-sim0 bus 0 scbus11 target 0 lun 0 da0: <hp v125w 1.00> Removable Direct Access SCSI-4 device da0: Serial Number 002354D4527DAC3172CF0065 da0: 40.000MB/s transfers da0: 15300MB (31334400 512 byte sectors: 255H 63S/T 1950C) da0: quirks=0x2<NO_6_BYTE> GEOM_RAID5: Module loaded, version 1.1.20130907.44 (rev 5c6d2a159411) ZFS filesystem version: 5 ZFS storage pool version: features support (5000) GEOM_ELI: Device ada1p1.eli created. GEOM_ELI: Encryption: AES-XTS 256 GEOM_ELI: Crypto: software GEOM_ELI: Device ada0p1.eli created. GEOM_ELI: Encryption: AES-XTS 256 GEOM_ELI: Crypto: software GEOM_ELI: Device ada3p1.eli created. GEOM_ELI: Encryption: AES-XTS 256 GEOM_ELI: Crypto: software GEOM_ELI: Device ada2p1.eli created. GEOM_ELI: Encryption: AES-XTS 256 GEOM_ELI: Crypto: software vboxdrv: fAsync=0 offMin=0x5cd offMax=0x1b64
zpool status -v
~# zpool status -v pool: v1 state: ONLINE status: Some supported features are not enabled on the pool. The pool can still be used, but some features are unavailable. action: Enable all features using 'zpool upgrade'. Once this is done, the pool may no longer be accessible by software that does not support the features. See zpool-features(7) for details. scan: scrub repaired 0 in 2h7m with 0 errors on Sun Jun 7 02:07:47 2015 config: NAME STATE READ WRITE CKSUM v1 ONLINE 0 0 0 gptid/e0d7536e-53d3-11e3-9789-50e549cd8552 ONLINE 0 0 0 errors: No known data errors
zpool import
~# zpool import pool: v0 id: 6859802526440201018 state: UNAVAIL status: One or more devices are missing from the system. action: The pool cannot be imported. Attach the missing devices and try again. see: http://illumos.org/msg/ZFS-8000-6X config: v0 UNAVAIL missing device mirror-1 ONLINE gptid/47a9fa47-71bc-11e3-9a43-50e549cd8552 ONLINE gptid/475baea4-53cd-11e3-bc1a-50e549cd8552 ONLINE mirror-2 DEGRADED 6440307554711772873 UNAVAIL cannot open gptid/8524bf6a-62cc-11e4-bb8a-50e549cd8552 ONLINE Additional devices are known to be part of this pool, though their exact configuration cannot be determined.
