Now it was a good while ago i installed my freenas and had som problems setting it up getting it to work right. After fiddling around alot i managed to get it working. I have 6x3tb wd red drives in raidz1. I began to transfer over files but after fiddling som more in the settings i couldnt access my files on freenas. read a bunch on the forum and some other places aswell and managed to get it working but lost almost 3tb of drivespace. im totaly green on freenas so i dont know what i did exactly but i think i did something like
- Created a user and set up my drives as raidz-1 with the wizard.
-All worked and i started transfering my mediafiles to the nas.
-Started tampering with other users and tried to configure SMB sharing.
-Changed something and i couldnt access my files anymore.
-In my attempt to find the problem Created a new dataset.
-Managed to get access to that dataset and SMB working.
-Started to transfer files again in to that Dataset.
But that dataset is almost 3tb smaller than what my total was before.
What have i done and what can i do to fix it?
Im running FreeNAS-9.10.2-U2 (e1497f2)
My Server Spec:
Core I7 2600K
Asus maximus IV Extreme
16 Gb DDR3
Radeon 7970
6x3tb WD red drives
My Server Spec:
Core I7 2600K
16 Gb DDR3
Radeon 7970
6x3tb WD red drives
