Mirrored USB drive degraded - what to do?
BlackHeart
I still pretty new to the world of Freenas, and now I've run into my first drive failure.
Luckily it's one of my two mirrored USB boot drives, and from what I can understand I can replace it with a similar or larger USB key.
My questions are:
1: How do I identify which of the two identical USB keys is defective?
2: Could a reformat on a Windows bring it back to life or should I just replace it?
3: When it's been identified and replaced/reformatted what steps must I perform in order to reestablish the mirroring?
A screenshot of System-Boot-Status can be seen here:
http://imgur.com/o0VohVw
Yatti420
I would run it under a flash testing tool see if it produces errors.. Try camcontrol devlist .. or geom disk list see if that can get you the info you need to identify.. I just replaced both my sticks after backing up USB last time (they both could barely hold data - would produce errors).. I just popped in my new USBs and selected replace (they were pre-formatted FAT from the retail packaging)..
Yatti420
gpart list should also correspond to the long ID your seeing there..
Mirfster
Better to just replace it. With a cheap older SSD if you can ;)
Same steps as you would when replacing any other drive
Arwen
Some USB drives have activity LEDs. Thus, if you perform a scrub on your boot pool,
(which will hit your only working USB drive), any LED would light up the working USB
drive. Replace the other.
Strangely enough, I've done this is production data centers when dealing with less
experienced field support staff, (though with 2.5" or 3.5" drives).
BlackHeart
Thanks for all the advice :)
Very good idea - it worked perfectly.
And I guess there is something seriously wrong the USB drive, it didn't even register on my Windows PC - so I've ordered a new one (identical model).
And how do I do that? Once I've gotten the replacement drive of course.
