By trying to get a straight answer to my question, I wanted to make sure that I wasn't heading down the wrong way. The first response to my question did not offend me at all; it was helpful, but not direct. As a new user, I wouldn't want to invest time reading a product's manual if the answer is straight No or barrier to entry is unacceptable. It was a question about a possible path to start using the product. I've been burnt by flashy claims by products (open source and commercial), so I want to make sure I use the right and supported configuration only. I would give straight answer *and* point to the other material /end-of-this-subtopic
Yes, RTFM is an absolute necessity when it comes to trusting a system with your precious data. cyberjock's presentation gives a good head start, though.
Thank you all!
PS: Messages from this thread, except the first one by Ericlowe, were filtered away by GMail spam filter. Didn't even know I was being responded to here.
PPS: The presentation does not render well in OpenOffice; some text from the material flows off the screen.
PPPS: I still can't get over the fact that UPS is a necessity to protect against corruption; I'll RTFM and hopefully gain a better insight.
