Hi all.
I have a FreeBSD machine at home that I've been running since... basically 2003. It's gone through numerous hardware and software upgrades since then, but while I was interested in tinkering with the machine back then, today I really just want the thing to sit and do its job and not have to worry about it. As such, I'd like to migrate the machine from FreeBSD where I have to do all of the software management myself to FreeNAS where everything is more... turn-key. The machine is currently running FreeBSD 12.1.
Right now the machine essentially serves two functions:
Thanks in advance.
- File server (AFP and NFS)
- VM host (a few Linux machines, managed by bhyve)
- root pool
- 2x SATA SSDs connected to the motherboard's SATA controller
- mirrored vdevs
- storage pool
- 4x SATA HDDs connected to an LSI SAS-9217 HBA (the HP OEM branded version of the SAS-9207)
- 2x2 mirrored vdevs
- 2x NVMe SSDs in M.2-to-PCI adapters (the system BIOS does not support booting from NVMe devices)
- each split into two partitions
- mirrored logs
- striped L2ARC
- FreeNAS will be able to read the storage pool without risk of data loss, and
- Once I recreate the VMs in FreeNAS, will I be able to point them to the zvols that currently represent their virtual disks, will they work as if nothing changed?
Thanks in advance.
