UPDATE: Chose to just import stuff manually, no easy way to migrate that way for what I was attempting.
So I decided to buy a full rack mount server instead of using the normal PC components in a 4U rack chassis. Problem I didnt think of was migrating my 6x3.5" drives.
The old system had a 2.5" 240gb SSD for boot, 4x2TB 3.5" drives as storage and 2x4TB 3.5" drives as a system dataset pool. I need to migrate the system dataset pool to the new system (its a fresh install with intention of copying config over) which is only 2.5" drives, otherwise I would have just took the old drives out and put them in the new system. Additionally, the new system I dont have any sata connections, its SAS only.
Is it worth trying to migrate it this way or just start afresh and setup everything again?
