Middleware schema migration
carpus
Hey everyone,
I wanted to contribute something to the cloud sync middleware, which requires changing the database schema (replacing a column, more specifically the boolean "follow_symlink" with the text column "symlink"). I have already found other migration stuff, and I have a migration for the actual data:
async def migrate(middleware):
    tasks = await middleware.call('datastore.query', 'tasks.cloudsync')
    for task in tasks:
        await middleware.call("datastore.update", "tasks.cloudsync", task['id'], {
                'symlinks': 'FOLLOW' if task['follow_symlinks'] == True else 'IGNORE'
However, this does not migrate the actual database schema. I cannot find any existing migrations doing this, nor can I find any documentation on this. The files in middlewared/plugins/datastore, which seems to be the source for e.g. the 'datastore.query' call, does contain a schema.py file. But this file only contains internal functions.
Is there a way to migrate the schema of a table in a datastore or does it get migrated automatically somehow?
Thanks!
anodos
Sambassador
Hey everyone,
    for task in tasks:
Thanks!
I think following symlinks in a cloudsync task is inherently problematic. For instance, if your dataset contains a backup of user home directory that contains a wine profile (which often has symlinks back to `/`) you can create an infinite loop.
carpus
You are right, which is why I would like to extend the symlink option beyond the current option to follow symlinks (rclone -L) with the additional option to copy symlinks as a reference (rclone -l), where the symlink is converted to a text file with an .rclonelink file extension. This would mitigate the problem you mentioned while still being able to copy symlinks.
