Gaspetaahl
- Sep 13, 2018
Hey,
so Ive been researching different NAS topics the last week and settled on a build that Im more or less happy with. My Budget is kinda limited but I still want to have a system that is easily upgradable. Also I wanted to use ECC RAM, so this is what I came up with. (Its more or less build upon this German guide if you are interested: https://www.elefacts.de/test-32-nas_advanced_1.0__intel_kaby_lake_mit_ecc_ram_6x_sata_und_m.2)
Also encryption is really important to me. OpenZFS encryption isnt there yet unfortunatly so I have to use geli for now. Shouldnt be a big problem with a AES-Ni processor-though
Motherboard: Gigabyte GA-X150M-PRO ECC https://www.amazon.de/dp/B01AVPAJWW...&creativeASIN=B01AVPAJWW&tag=geizhalspre03-21
My idea here was to have a cheap Mainboard that supports ECC RAM. It has also got a Intel C Chipset but unfortunatly no onboard-gpu. Thats why the GPU is in the list(for first install).
CPU: Intel Pentium Gold G4560, 2x 3.50GHz https://www.amazon.de/Intel-Pentium-G4560-50GHz-Boxed/dp/B01N7U18M1/ref=olp_product_details?_encoding=UTF8&me=
I think this is enough CPU for me. I dont want to do that much on the NAS. Maybe use pyload or plex. But thats not what I actually need it for.
RAM: Kingston ValueRAM Intel DIMM 8GB, DDR4-2133, CL15-15-15, ECC (KVR21E15D8/8I) https://www.amazon.de/dp/B01FSUOY2Q...&creativeASIN=B01FSUOY2Q&tag=geizhalspre03-21
I wasnt able to find any of the Vendors reccommodations from here: download.gigabyte.eu/FileList/Memory/mb_memory_ga-x150m-pro-ecc.pdf
Maybe you have a tip for me? (I needs to be shipeed to Germany)
I wanted to start with 8GB an then upgrade later.
System SSD: Intel SSD E 6000p 128GB, M.2 (SSDPEKKR128G7XN) https://www.amazon.de/dp/B01LWR6QLN?smid=ACMIUR0TOLYDM&linkCode=df0&creative=22510&creativeASIN=B01LWR6QLN&childASIN=B01LWR6QLN&tag=geizhals10-21
The Idea here was to have a NVMe SSD to not use one of the 6 SATA Ports from the Mainboard. Its not that fast but cheap. Could I use the left over space for cache? Should I buy a better SSD then?
PSU: be quiet! System Power 9 400W ATX 2.4 (BN245) https://www.amazon.de/quiet-Netzteil-System-Power-BN245/dp/B079KG3TZ5/ref=olp_product_details?_encoding=UTF8&me=
GPU: Sapphire Radeon R5 230, 1GB DDR3 https://www.amazon.de/dp/B00JM49ECK?smid=A1HTKBNYG718CQ&linkCode=df0&creative=22514&creativeASIN=B00JM49ECK&childASIN=B00JM49ECK&tag=geizhals10-21
Case: Fractal Design Node 804 https://www.amazon.de/dp/B00JBBH93K?linkCode=xm2&camp=2025&creative=165953&smid=A3JWKAKR8XB7XF&creativeASIN=B00JBBH93K&tag=geizhalspre03-21
This is a nice Case but also a bit expensive. Actually I wanted to use a Xigmatek Asgard II (https://www.amazon.de/gp/product/B0...eASIN=B003D0ET2O&linkCode=as2&tag=elefacts-21) but its not available at the moment. Any other suggestions?
HDDs: Not quite sure yet but I was thinking about 4x 4TB WD Red in a RAIDZ2 an upgrading later when OpenZFS RAIDZ Upgrading is supported.
Thank you very much for any help
