Hello all. I just installed FreeNAS 8 a week ago and after some initial difficulties (mostly hardware, not FreeNAS fault) I got it running. This is my first go-round with freenas, my fileserver previously ran XP (blah, box was not intended to be a fileserver originally and did not get rebuilt as it morphed into one).
I hadn't looked at the 'minimum requirements' before installing. My box is an AMD Athlon64 X2 3800+ with 1GB of RAM, booting from a USB stick. Highpoint RocketRAID 1740 controller with 4x 2TB Samsung Spinpoint F4 drives (in a RAID5), and 2 standalone 2TB drives. I notice now that the min reqs page says 4GB of RAM is necessary. I am not using ZFS and will not try it until I have upgraded to at least 4GB of RAM, but that won't likely be for awhile.
So, my concern is that I am frequently seeing 99%+ memory utilization. Right now, there is 4MB of RAM free on the system. Right after a reboot, I've got about 200MB free. Should I expect freenas to eat more RAM as it stays up? I'd prefer to almost never reboot the box if possible. Is there anything I can turn off, such as disabling ZFS support somehow? I know about editing config files where they are loaded into the ramdisk from, I just don't know what to edit.
Right now, the processes eating significant RAM seem to be (I'm just checking top... is there a way to get top to display processes by RAM usage? Or perhaps another tool? I'm very familiar with *nix systems, but from a development rather than sysadmin POV): python using 105M, smbd using 102M, rpc.statd using 263M. I have SSH, FTP, CIFS, NFS turned on as far as services go. I've got 3 volumes, each shared both as a samba share and an NFS share (I've got a few Ubuntu clients that mount the NFS shares). Am I simply being unrealistic wanting to run this configuration with only 1GB of RAM? Should I consider using freenas 0.7? If so, will everything port over? My volumes are UFS volumes.
Thanks in advance for any info.
