Reply, worth a shot. However i have a similar make and model board, but mine does show the bank info...so thats why im a little confused.
Physical Memory Array
Use: System Memory
Error Correction Type: Multi-bit ECC
Maximum Capacity: 192 GB
Error Information Handle: Not Provided
Number Of Devices: 6
Handle 0x0015, DMI type 19, 15 bytes
Memory Array Mapped Address
Starting Address: 0x00000000000
Ending Address: 0x005FFFFFFFF
Range Size: 24 GB
Physical Array Handle: 0x0014
Partition Width: 3
Handle 0x0016, DMI type 17, 28 bytes
Memory Device
Total Width: 72 bits
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: P1-1A
Bank Locator: BANK0
Type: DDR3
Type Detail: Other
Speed: 1066 MHz
Manufacturer: Kingston
Serial Number: 0C3E264D
Asset Tag: AssetTagNum0
Part Number: 9965516-069.A00LF
Rank: Unknown
Handle 0x0017, DMI type 20, 19 bytes
Memory Device Mapped Address
Ending Address: 0x001FFFFFFFF
Range Size: 8 GB
Physical Device Handle: 0x0016
Memory Array Mapped Address Handle: 0x0015
Partition Row Position: 1
Interleave Position: Unknown
Interleaved Data Depth: 2
Handle 0x0018, DMI type 17, 28 bytes
Memory Device
Data Width: 64 bits
Size: No Module Installed
Form Factor: DIMM
Set: None
Locator: P1-1B
Bank Locator: BANK1
Type: DDR3
Type Detail: Other
Speed: Unknown
Manufacturer: Manufacturer01
Serial Number: SerNum01
Asset Tag: AssetTagNum1
Part Number: ModulePartNumber01
Rank: Unknown
Handle 0x0019, DMI type 20, 19 bytes
Ending Address: 0x000000003FF
Range Size: 1 kB
Physical Device Handle: 0x0018
Handle 0x001A, DMI type 17, 28 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: P1-2A
Bank Locator: BANK2
Type: DDR3
Type Detail: Other
Speed: 1066 MHz
Serial Number: 0A4A26EA
Asset Tag: AssetTagNum2
Rank: Unknown
Handle 0x001B, DMI type 20, 19 bytes
Starting Address: 0x00200000000
Ending Address: 0x003FFFFFFFF
Range Size: 8 GB
Physical Device Handle: 0x001A
Handle 0x001C, DMI type 17, 28 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: P1-2B
Bank Locator: BANK3
Type: DDR3
Type Detail: Other
Speed: Unknown
Manufacturer: Manufacturer03
Serial Number: SerNum03
Asset Tag: AssetTagNum3
Part Number: ModulePartNumber03
Rank: Unknown
Handle 0x001D, DMI type 20, 19 bytes
Range Size: 1 kB
Physical Device Handle: 0x001C
Handle 0x001E, DMI type 17, 28 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: P1-3A
Bank Locator: BANK4
Type: DDR3
Type Detail: Other
Speed: 1066 MHz
Serial Number: 0A6026EB
Asset Tag: AssetTagNum4
Rank: Unknown
Handle 0x001F, DMI type 20, 19 bytes
Starting Address: 0x00400000000
Range Size: 8 GB
Physical Device Handle: 0x001E
Handle 0x0020, DMI type 17, 28 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: P1-3B
Bank Locator: BANK5
Type: DDR3
Type Detail: Other
Speed: Unknown
Manufacturer: Manufacturer05
Serial Number: SerNum05
Asset Tag: AssetTagNum5
Part Number: ModulePartNumber05
Rank: Unknown
Handle 0x0021, DMI type 20, 19 bytes
Range Size: 1 kB
Physical Device Handle: 0x0020
Handle 0x0022, DMI type 16, 15 bytes
Use: System Memory
Handle 0x0023, DMI type 19, 15 bytes
Starting Address: 0x00600000000
Ending Address: 0x00BFFFFFFFF
Range Size: 24 GB
Physical Array Handle: 0x0022
Partition Width: 3
Handle 0x0024, DMI type 17, 28 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: P2-1A
Bank Locator: BANK6
Type: DDR3
Type Detail: Other
Speed: 1066 MHz
Serial Number: 0B1426E9
Asset Tag: AssetTagNum6
Rank: Unknown
Handle 0x0025, DMI type 20, 19 bytes
Ending Address: 0x007FFFFFFFF
Range Size: 8 GB
Physical Device Handle: 0x0024
Memory Array Mapped Address Handle: 0x0023
Handle 0x0026, DMI type 17, 28 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: P2-1B
Bank Locator: BANK7
Type: DDR3
Type Detail: Other
Speed: Unknown
Manufacturer: Manufacturer07
Serial Number: SerNum07
Asset Tag: AssetTagNum7
Part Number: ModulePartNumber07
Rank: Unknown
Handle 0x0027, DMI type 20, 19 bytes
Range Size: 1 kB
Physical Device Handle: 0x0026
Handle 0x0028, DMI type 17, 28 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: P2-2A
Bank Locator: BANK8
Type: DDR3
Type Detail: Other
Speed: 1066 MHz
Serial Number: 0B9A26ED
Asset Tag: AssetTagNum8
Rank: Unknown
Handle 0x0029, DMI type 20, 19 bytes
Starting Address: 0x00800000000
Ending Address: 0x009FFFFFFFF
Range Size: 8 GB
Physical Device Handle: 0x0028
Handle 0x002A, DMI type 17, 28 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: P2-2B
Bank Locator: BANK9
Type: DDR3
Type Detail: Other
Speed: Unknown
Manufacturer: Manufacturer09
Serial Number: SerNum09
Asset Tag: AssetTagNum9
Part Number: ModulePartNumber09
Rank: Unknown
Handle 0x002B, DMI type 20, 19 bytes
Range Size: 1 kB
Physical Device Handle: 0x002A
Handle 0x002C, DMI type 17, 28 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: P2-3A
Bank Locator: BANK10
Type: DDR3
Type Detail: Other
Speed: 1066 MHz
Serial Number: 0C0526E9
Asset Tag: AssetTagNum10
Rank: Unknown
Handle 0x002D, DMI type 20, 19 bytes
Starting Address: 0x00A00000000
Range Size: 8 GB
Physical Device Handle: 0x002C
Handle 0x002E, DMI type 17, 28 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: P2-3B
Bank Locator: BANK11
Type: DDR3
Type Detail: Other
Speed: Unknown
Manufacturer: Manufacturer11
Serial Number: SerNum11
Asset Tag: AssetTagNum11
Part Number: ModulePartNumber11
Rank: Unknown
Handle 0x002F, DMI type 20, 19 bytes
Range Size: 1 kB
Physical Device Handle: 0x002E
Handle 0x0030, DMI type 32, 20 bytes
System Boot Information
Status: No errors detected
Handle 0x0031, DMI type 38, 18 bytes
IPMI Device Information
Interface Type: Unknown
Specification Version: 0.0
I2C Slave Address: 0x00
NV Storage Device: Not Present
Base Address: 0x0000000000000000 (Memory-mapped)
Register Spacing: Successive Byte Boundaries
