FreeNas Beta 2.1-2
I thought FR ZFS cache used all available memory. Plex became unusable and looked at the dashboard and found this :
I have 56TB total space and 23TB being used right now. I have another 32GB OTW. I know it should be ECC ......long story for another time.
Plex was going to heck and switched around the various Beta's .... I'd go back to 11.3, but another long story of not being aware how to properly switch between boot images. I'm learning the HARD way ..... as usual. I think I'm stuck with the Beta. I have plenty of configs saved. Hopefully RC is around the corner. The only settings I've messed with are permissions.
At one time Plex transcoding had multiple instances with 70% CPU usage when no clients were active for some time. That's about all the peculiar goings on.
Everything was fine ..... and then it all went downhill all of a sudden ....
Jails :
Plex
HDHomeRun
MiniDLNA
TIA Kevin
Jails :
Plex
HDHomeRun
MiniDLNA
TIA Kevin
