Hey everyone,
I've gotten my hands on a few things that I would like to make a FreeNAS storage server with, but I'm running into a few issues.
Hardware:
Supermicro 6016T-6RFT+ with 96GB of RAM:
Intel® Xeon® processor 5600/5500 series, with QPI up to 6.4 GT/s
288GB** DDR3 1333/ 1066/800MHz ECC Registered DIMM / 48GB Unbuffered DIMM
Left Slot (Full-height / Full-length): 2 (x8) PCI-E 2.0 slots
Right Slot (Low-Profile - 5.5" depth): 1 (x4) PCI-E 2.0 (in x8 slot)
Broadcom 2108 8-Port 6Gbps SAS Controller; RAID 0, 1, 5, 6, 10
Intel® 82599EB 10 Gigabit + 82576 Dual-Port Gigabit Ethernet Controller
4x 3.5" Hot-swap SAS/SATA Drives, For Customizable Storage
700W Gold-Level Redundant Power Supply
Chenbro RM519 case
Areca ARC-1280ML (which might be able to work according to Link)https://www.freebsd.org/cgi/man.cgi?query=arcmsr&sektion=4&manpath=FreeBSD+11.0-RELEASE+and+Ports
24x 4TB harddisks(TBD)
Because the Supermicro doesn't fit into the Chenbro case, I was contemplating putting the Raid controller in the Supermicro server and then have the SAS cables run between the 2 servers, but unfortunately the raid card has active cooling and doesn't fit in the 1U case. I could probably get my hands on a passive cooler somewhere, but then I would like to be more certain that the ARC-1280ML would work.
Another option I had in mind was to use a PCI extender cable between the two cases and put the ARC-1280ML in the Chenbro case, which would save me from having to buy longer SAS cables, but I was persuaded against this by people using a lot of sarcasm and no real explanation on why this is a terrible idea.
Third option and probably the "official option" would be to use external SAS like in this example.
I understand that this all might not be optimal but I would like to see what the downsides are of each option, because I've not been able to find any information about these cases(probably because other people aren't this idiotic).
The final option which I'm also considering is getting an extra motherboard and CPU that do fit in the Chenbro case and just steal a bunch of the memory from the supermicro (any recommendations are welcome, I am from Europe though, so what is cheap for you might be 3 times as expensive on this side of the pond).
I understand that this post might be a mess but I would ask you to bear with me, I'm trying to find all the information on my own but sometimes one just needs a bit of guidance.
Thanks for reading through this far and any help and tips are welcome!
TL;DR: Idiot got his hands on decent hardware and doesn't know what to do with it.
Hardware:
Chenbro RM519 case
