May I have your opinion on what happened?
AuBird
Thank you for taking the time to look at this post. Yesterday my certified 4U FreeNAS running FreeNAS-9.10.2-U6 (561f0d7a1) kicked off an email saying one or more devices experienced an error. When I logged in to investigate the zpool status -v output was something like below, and I did see the CKSUM column increment by 20-30. Then all of the sudden the system rebooted and all the CKSUM numbers are back at zero. All data on the iSCSI share appears to be okay, the backup application using the share hasn't reported any integrity issues yet.
From what I've read this means there is a disk in trouble or bad memory. I've attached the output of smartctl -a for all active multipaths. Is it likely bad memory? Would memtest catch any errors with ECC memory? Or are there a few bad drives? Any idea why the system would just reboot? I wasn't able to see anything in the logs other than cases being built for the raidz2-1 vdev, and I don't know what that means.
EDIT: Just one more thing, I did upgrade from 9.3 to 9.10 a couple days ago.
[root@freenas] ~# zpool status -v
  pool: fnas01p01
 state: ONLINE
		corruption.  Applications may be affected.
action: Restore the file in question if possible.  Otherwise restore the
		entire pool from backup.
   see: http://illumos.org/msg/ZFS-8000-8A
  scan: scrub repaired 0 in 13h41m with 0 errors on Sun Nov 26 13:41:51 2017
		NAME											STATE	 READ WRITE CKSUM
		fnas01p01									   ONLINE	   0	 0   107
		  raidz2-0									  ONLINE	   0	 0	 0
			gptid/dc9a2811-615c-11e5-929b-0cc47a55b944  ONLINE	   0	 0	 0
			gptid/dce660b8-615c-11e5-929b-0cc47a55b944  ONLINE	   0	 0	 0
			gptid/dd342422-615c-11e5-929b-0cc47a55b944  ONLINE	   0	 0	 0
			gptid/dd830db8-615c-11e5-929b-0cc47a55b944  ONLINE	   0	 0	 0
			gptid/ddd197f0-615c-11e5-929b-0cc47a55b944  ONLINE	   0	 0	 0
			gptid/de20caf7-615c-11e5-929b-0cc47a55b944  ONLINE	   0	 0	 0
			gptid/de70e4c0-615c-11e5-929b-0cc47a55b944  ONLINE	   0	 0	 0
			gptid/debecb5a-615c-11e5-929b-0cc47a55b944  ONLINE	   0	 0	 0
			gptid/df0e3e33-615c-11e5-929b-0cc47a55b944  ONLINE	   0	 0	 0
			gptid/df5e1829-615c-11e5-929b-0cc47a55b944  ONLINE	   0	 0	 0
			gptid/dfaea5ca-615c-11e5-929b-0cc47a55b944  ONLINE	   0	 0	 0
		  raidz2-1									  ONLINE	   0	 0   214
			gptid/d880b4e4-62b8-11e5-929b-0cc47a55b944  ONLINE	   0	 0	 0
			gptid/d8ed9dcd-62b8-11e5-929b-0cc47a55b944  ONLINE	   0	 0	 0
			gptid/d95e33ef-62b8-11e5-929b-0cc47a55b944  ONLINE	   0	 0	 0
			gptid/d9c8a064-62b8-11e5-929b-0cc47a55b944  ONLINE	   0	 0	 0
			gptid/da3642fb-62b8-11e5-929b-0cc47a55b944  ONLINE	   0	 0	 0
			gptid/daa1e095-62b8-11e5-929b-0cc47a55b944  ONLINE	   0	 0	 0
			gptid/db0bc938-62b8-11e5-929b-0cc47a55b944  ONLINE	   0	 0	 0
			gptid/db7cfec9-62b8-11e5-929b-0cc47a55b944  ONLINE	   0	 0	 0
			gptid/dbeac94c-62b8-11e5-929b-0cc47a55b944  ONLINE	   0	 0	 0
			gptid/dc567379-62b8-11e5-929b-0cc47a55b944  ONLINE	   0	 0	 0
			gptid/dcc284fc-62b8-11e5-929b-0cc47a55b944  ONLINE	   0	 0	 0
		spares
		  gptid/e00654c8-615c-11e5-929b-0cc47a55b944	AVAIL
		  gptid/bcabc891-62ba-11e5-929b-0cc47a55b944	AVAIL
		fnas01p01/rep01lun02:<0x1>
  • freenas01-driveinfo.txt
Chris Moore
Do you have any monitoring scripts setup or is the system running the standard build with no adjustments or custom setting?
AuBird
It's standard, I just added scheduled SMART tests. No custom settings, there is something about snmp in the tunables, but I'm pretty sure that is stock.
AuBird
I added the fact this was upgraded from 9.3 to 9.10 just a couple days ago, maybe the day before this error kicked out?
Chris Moore
I was looking at your attached text file. It appears to be generated by a script that I am not familiar with. Due to the function of the script, the data is incomplete and presented in an unusual format. This makes it difficult to tell if there is a problem with one of your drives, but I will look at it further. The unfiltered output of smartctl -a /dev/daXX would be easier to read.
I would suggest that, if there is not some compelling reason preventing it, you should upgrade to the latest version of the OS.
In addition to that, you should utilize some of the scripts here:
https://forums.freenas.org/index.ph...for-freenas-scripts-including-disk-burnin.28/
to keep an eye on the function of the drives.
Is this a personal system or is it being used in a business environment?
Chris Moore
'cases' are how the system keeps track of accumulated errors that a drive is experiencing. If the drive experiences enough errors, ZFS will mark the drive as failed. Since you have hot-spares, and RAID-z2, I would expect your data to be safe, however there is the error at the end of your zpool status
The naming on that file makes it look like an iSCSI extent, but you said that the applications were working.
I don't think this is a RAM error. From what I see, I would expect some disk subsystem error. Either a disk, or disks, or the controller.
I noticed a line, "Drive Trip Temperature: 85 C", in your text file. What is the significance of this?
AuBird
This is in a business environment, not heavily used and only stores our backups. I'll take a look at the next stable branch and the scripts, thank you.
I threw the script together so I could easily get output of smartctl -a /dev/daXX without running it for each drive. It's just a for loop running through all the ACTIVE multipath drives.
AuBird
The "Drive Trip Temperature: 85 C" line is part of the output from smartctl -a /dev/da1, and I assume it's the drives temperature limit suggested by the manufacture.
[root@freenas] ~# smartctl -a /dev/da1
smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
Vendor:			   HGST
Product:			  HUS724040ALS640
Revision:			 A280
Compliance:		   SPC-4
User Capacity:		4,000,787,030,016 bytes [4.00 TB]
Logical block size:   512 bytes
LU is fully provisioned
Rotation Rate:		7200 rpm
Form Factor:		  3.5 inches
Logical Unit id:	  0x5000cca05cd295fc
Serial number:		PCKRU81X
Device type:		  disk
Transport protocol:   SAS (SPL-3)
Local Time is:		Thu Nov 30 09:44:06 2017 EST
SMART support is:	 Available - device has SMART capability.
SMART support is:	 Enabled
Temperature Warning:  Enabled
SMART Health Status: OK
Current Drive Temperature:	 33 C
Manufactured in week 11 of year 2015
Specified cycle count over device lifetime:  50000
Accumulated start-stop cycles:  17
Specified load-unload count over device lifetime:  600000
Accumulated load-unload cycles:  2405
Elements in grown defect list: 0
Vendor (Seagate) cache information
  Blocks sent to initiator = 17665617016389632
Error counter log:
		   Errors Corrected by		   Total   Correction	 Gigabytes	Total
			   ECC		  rereads/	errors   algorithm	  processed	uncorrected
		   fast | delayed   rewrites  corrected  invocations   [10^9 bytes]  errors
read:	 198854		0		 0	198854   16679186	 115332.008		   0
write:		 0		0		 0		 0	 150285	  22177.758		   0
verify:		0		0		 0		 0	 817121		  0.000		   0
Non-medium error count:		0
SMART Self-test log
Num  Test			  Status				 segment  LifeTime  LBA_first_err [SK ASC ASQ]
	 Description							  number   (hours)
# 1  Background short  Completed				   -   19450				 - [-   -	-]
# 2  Background long   Completed				   -   19447				 - [-   -	-]
Long (extended) Self Test duration: 37452 seconds [624.2 minutes]
[root@freenas] ~#
Chris Moore
I have dealt with a lot of drives, even HGST, but this is a very different output than I usually see. The specifics change from one model to another even in the same vendor, but the part at the bottom usually looks more like this:
ID# ATTRIBUTE_NAME		  FLAG	 VALUE WORST THRESH TYPE	  UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate	 0x000f   117   099   006	Pre-fail  Always	   -	   135984832
  3 Spin_Up_Time			0x0003   096   096   000	Pre-fail  Always	   -	   0
  4 Start_Stop_Count		0x0032   100   100   020	Old_age   Always	   -	   95
  5 Reallocated_Sector_Ct   0x0033   100   100   010	Pre-fail  Always	   -	   0
  7 Seek_Error_Rate		 0x000f   077   060   030	Pre-fail  Always	   -	   50498920
  9 Power_On_Hours		  0x0032   094   094   000	Old_age   Always	   -	   5370
 10 Spin_Retry_Count		0x0013   100   100   097	Pre-fail  Always	   -	   0
 12 Power_Cycle_Count	   0x0032   100   100   020	Old_age   Always	   -	   87
183 Runtime_Bad_Block	   0x0032   100   100   000	Old_age   Always	   -	   0
184 End-to-End_Error		0x0032   100   100   099	Old_age   Always	   -	   0
187 Reported_Uncorrect	  0x0032   100   100   000	Old_age   Always	   -	   0
188 Command_Timeout		 0x0032   100   100   000	Old_age   Always	   -	   0 0 0
189 High_Fly_Writes		 0x003a   097   097   000	Old_age   Always	   -	   3
190 Airflow_Temperature_Cel 0x0022   070   053   045	Old_age   Always	   -	   30 (Min/Max 28/33)
191 G-Sense_Error_Rate	  0x0032   100   100   000	Old_age   Always	   -	   0
192 Power-Off_Retract_Count 0x0032   100   100   000	Old_age   Always	   -	   52
193 Load_Cycle_Count		0x0032   100   100   000	Old_age   Always	   -	   715
194 Temperature_Celsius	 0x0022   030   047   000	Old_age   Always	   -	   30 (0 20 0 0 0)
197 Current_Pending_Sector  0x0012   100   100   000	Old_age   Always	   -	   0
198 Offline_Uncorrectable   0x0010   100   100   000	Old_age   Offline	  -	   0
199 UDMA_CRC_Error_Count	0x003e   200   200   000	Old_age   Always	   -	   0
240 Head_Flying_Hours	   0x0000   100   253   000	Old_age   Offline	  -	   5323h+24m+33.496s
241 Total_LBAs_Written	  0x0000   100   253   000	Old_age   Offline	  -	   26028475929
242 Total_LBAs_Read		 0x0000   100   253   000	Old_age   Offline	  -	   1030194009260
No Errors Logged
Test_Description	Status				  Remaining  LifeTime(hours)  LBA_of_first_error
Extended offline	Completed without error	   00%	  5365		 -
AuBird
My drives at home show tables like that as well, but this FreeNAS and and another running FreeNAS 11 show the same strange output with these HGST drives. So far I haven't found a way to get the same sort of information you listed from these drives.
AuBird
I started a scrub on the pool this morning, but just stopped it after seeing this output which spooked me. I might just pull these drives and throw them into our spare and run a scrub there.
  pool: fnas01p01
 state: ONLINE
  scan: scrub canceled on Thu Nov 30 10:11:30 2017
		fnas01p01									   ONLINE	   0	 0   109
		  raidz2-0									  ONLINE	   0	 0   108
			gptid/dc9a2811-615c-11e5-929b-0cc47a55b944  ONLINE	   0	 0	 9
			gptid/dce660b8-615c-11e5-929b-0cc47a55b944  ONLINE	   0	 0	10
			gptid/dd342422-615c-11e5-929b-0cc47a55b944  ONLINE	   0	 0	10
			gptid/dd830db8-615c-11e5-929b-0cc47a55b944  ONLINE	   0	 0	 4
			gptid/ddd197f0-615c-11e5-929b-0cc47a55b944  ONLINE	   0	 0	 7
			gptid/de20caf7-615c-11e5-929b-0cc47a55b944  ONLINE	   0	 0	 6
			gptid/de70e4c0-615c-11e5-929b-0cc47a55b944  ONLINE	   0	 0	 5
			gptid/debecb5a-615c-11e5-929b-0cc47a55b944  ONLINE	   0	 0	 5
			gptid/df0e3e33-615c-11e5-929b-0cc47a55b944  ONLINE	   0	 0	 6
			gptid/df5e1829-615c-11e5-929b-0cc47a55b944  ONLINE	   0	 0	 9
			gptid/dfaea5ca-615c-11e5-929b-0cc47a55b944  ONLINE	   0	 0	 4
		  raidz2-1									  ONLINE	   0	 0   110
			gptid/d880b4e4-62b8-11e5-929b-0cc47a55b944  ONLINE	   0	 0	10
			gptid/d8ed9dcd-62b8-11e5-929b-0cc47a55b944  ONLINE	   0	 0	 3
			gptid/d95e33ef-62b8-11e5-929b-0cc47a55b944  ONLINE	   0	 0	 6
			gptid/d9c8a064-62b8-11e5-929b-0cc47a55b944  ONLINE	   0	 0	 6
			gptid/da3642fb-62b8-11e5-929b-0cc47a55b944  ONLINE	   0	 0	 5
			gptid/daa1e095-62b8-11e5-929b-0cc47a55b944  ONLINE	   0	 0	 5
			gptid/db0bc938-62b8-11e5-929b-0cc47a55b944  ONLINE	   0	 0	 5
			gptid/db7cfec9-62b8-11e5-929b-0cc47a55b944  ONLINE	   0	 0	11
			gptid/dbeac94c-62b8-11e5-929b-0cc47a55b944  ONLINE	   0	 0	 9
			gptid/dc567379-62b8-11e5-929b-0cc47a55b944  ONLINE	   0	 0	 2
			gptid/dcc284fc-62b8-11e5-929b-0cc47a55b944  ONLINE	   0	 0	14
		spares
		fnas01p01/rep01lun01:<0x1>
Chris Moore
Every drive in the text file you uploaded had a large number of errors:
- EDIT - except for the two hot spares. They have not been used, much.
Error counter log:
read:	 271040		3		 0	271043   16170787	 115075.134		   0
write:		 0		0		 0		 0	 320778	  22177.539		   0
verify:		0		0		 0		 0	  34814		  0.000		   0
Non-medium error count:		4
(internal in the drive) but, it appeared that the errors had been corrected.
The scrub information you just posted makes me wonder.
Then the following drives had "Non-medium" errors:
da24
Serial number:		PCKSEZEX
da42
Serial number:		PCKT1WHX
Non-medium error count:		1
I think I would let the scrub finish and see if it can fix the problems.
If the system is holding backups, you might not actually have a viable backup.
Chris Moore
Would you post the output of sas2flash so we can see the firmware version of the SAS controller.
AuBird
Just confirmed we got the data copied off yesterday
[root@freenas] ~# sas2flash
LSI Corporation SAS2 Flash Utility
Version 16.00.00.00 (2013.03.01)
Copyright (c) 2008-2013 LSI Corporation. All rights reserved
AuBird
Heh, I remember 16 being a thing for the 9.3 branch. I could easily upgrade the firmware, thank you.
EDIT: But the recent purchase from iXsystems with 11 on it is running the same version
root@freenasb11a:~ # sas2flash
		No LSI SAS adapters found! Limited Command Set Available!
		Finished Processing Commands Successfully.
		Exiting SAS2Flash.
AuBird
I've restarted the scrub.
Chris Moore
Sorry, the whole command is sas2flash -list which should give you an output like this:
		Adapter Selected is a LSI SAS: SAS2308_2(D1)
		Controller Number			  : 0
		Controller					 : SAS2308_2(D1)
		PCI Address					: 00:02:00:00
		SAS Address					: removed
		NVDATA Version (Default)	   : 14.01.00.06
		NVDATA Version (Persistent)	: 14.01.00.06
		Firmware Product ID			: 0x2214 (IT)
		Firmware Version			   : 20.00.07.00
		NVDATA Vendor				  : LSI
		NVDATA Product ID			  : SAS9207-8i
		BIOS Version				   : 07.39.00.00
		UEFI BSD Version			   : 07.27.01.00
		FCODE Version				  : N/A
		Board Name					 : SAS9207-8i
		Board Assembly				 : removed
		Board Tracer Number			: removed
		Exiting SAS2Flash.
The version 16 you are seeing is just the version of the utility.
AuBird
[root@freenas] ~# sas2flash -list
		Adapter Selected is a LSI SAS: SAS2308_1(D1)
		Controller					 : SAS2308_1(D1)
		PCI Address					: 00:01:00:00
		SAS Address					: 5003048-0-1897-ff01
		NVDATA Version (Default)	   : 14.01.00.12
		NVDATA Version (Persistent)	: 14.01.00.12
		Firmware Product ID			: 0x2714 (IR)
		Firmware Version			   : 20.00.02.00
		NVDATA Vendor				  : LSI
		NVDATA Product ID			  : LSI2308-IR
		FCODE Version				  : N/A
		Board Name					 : LSI2308-IR
		Board Assembly				 : N/A
		Board Tracer Number			: N/A
		Exiting SAS2Flash.
Chris Moore
I feel like this is wrong. That line should end with IT (Initiator Target) instead of IR. The IR firmware has the hardware RAID functionality and FreeNAS doesn't like that. The other thing, which doesn't feel like as big a deal, is this:
That firmware is a little out of date, if I recall correctly, the latest is: 20.00.07.00
I am not saying this is the problem, but it looks like a possibility. Did this system come from iXsystems configured like this?
