Hi All;
I have downloaded both the .iso file and the .xyz (or what ever the ending is) and have Burned then on a CD.. (Not on the same CD).. I have unzipped the .xyz file using 7-zip.. I don't know what kind of file ending it ends up with.. (.img or something similair, I think)
I have windows XP on my main machine and I am using an older Nero Burning software to Burn with.. (Which I am happy with)..
None of the DVD's I have burned are bootable on my Target machine.. It has the ability to boot from CD (DVD) but not from Jumpstick, as near as I can tell.. It does ask in the Bios if I can boot from other devices, But I am not sure that works.. At least the stick isn't seen..
I have a DVD with the FreeNAS .iso on it and another with FreeNAS and a bootable Dos system, neither of them will boot from the gitgo.. With the Dos prompt, I can go to Drive "D" and see the FreeNas files as listed, But I don't know how to run either type on with an .Img or the other DVD with the .Iso file
So what file or files Do I need to Write to my DVD and in what format ??
I hope I have given enought information for someOne to answer my question.. And not confused anyone..
THANK YOU Marty
THANK YOU Marty
