make_dev_physpath_alias: WARNING ....
dcevansiii
Here's my setup:
FreeNas 9.1.1​
Dell 440SC 2gb​
with lsi hba card -> 16 drive enclosure XJ-SA16-316R-B (only supports upto 1tb I believe)​
I am getting this message when I put in my new HD (1TB 3.5 SATA6 Seagate):
"make_dev_physpath_alias: WARNING - Unable to alias pass2 to enc@n50015b2180000a60/type@0/slot@1/elmdesc@Disk_0______________________/pass2 - path too long"​
zpool status gives me crazy long names for the disks, I assume because it can't properly alias the disks.
Here's the zpool status output from one pool:
pool: corpdata
state: ONLINE
scan: none requested
NAME STATE READ WRITE CKSUM
corpdata ONLINE 0 0 0
mirror-0 ONLINE 0 0 0
gptid/92a070e2-171e-11e3-9a70-002219074adf ONLINE 0 0 0
gptid/94e0aa03-171e-11e3-9a70-002219074adf ONLINE 0 0 0
errors: No known data errors
I've attached the full output from dmesg and zpool status.
Is this something that I need to worry about?
Thanks-
dce
  • 20130909_freenas_dmesg.txt
  • zpool_status.txt
dcevansiii
No I haven't. Any suggestions? I have a HP DL380 G6 that I was going to move the LSI card to and try it there, but I haven't done that yet. I suspect I'll get the same thing.
Thanks for responding and any thoughts?
dce
wtfuar
Same problem here after upgrading 8.3 to 9.1.1
Sep 23 18:02:37 freenas manage.py: [storage.forms:2065]
Sep 23 18:02:37 freenas kernel: GEOM_ELI: Device gptid/65977639-9d54-11e2-9312-000c29cec408.eli created.
Sep 23 18:02:37 freenas kernel: GEOM_ELI: Encryption: AES-XTS 128
Sep 23 18:02:37 freenas kernel: GEOM_ELI:    Crypto: hardware
Sep 23 18:02:37 freenas kernel: make_dev_physpath_alias: WARNING - Unable to alias gptid/65977639-9d54-11e2-9312-000c29cec408.eli to enc@n5001e6714955800b/type@0/slot@5/elmdesc@Disk_#4_/gptid/65977639-9d54-11e2-9312-000c29cec408.eli - path too long
Sep 23 18:02:37 freenas kernel: GEOM_ELI: Device gptid/66bc5d54-9d54-11e2-9312-000c29cec408.eli created.
Sep 23 18:02:37 freenas kernel: GEOM_ELI: Device gptid/622428ec-9d54-11e2-9312-000c29cec408.eli created.
Sep 23 18:02:37 freenas kernel: make_dev_physpath_alias: WARNING - Unable to alias gptid/622428ec-9d54-11e2-9312-000c29cec408.eli to enc@n5001e6714955800b/type@0/slot@2/elmdesc@Disk_#1_/gptid/622428ec-9d54-11e2-9312-000c29cec408.eli - path too long
Sep 23 18:02:37 freenas kernel: GEOM_ELI: Device gptid/634a7ede-9d54-11e2-9312-000c29cec408.eli created.
Sep 23 18:02:37 freenas kernel: make_dev_physpath_alias: WARNING - Unable to alias gptid/634a7ede-9d54-11e2-9312-000c29cec408.eli to enc@n5001e6714955800b/type@0/slot@3/elmdesc@Disk_#2_/gptid/634a7ede-9d54-11e2-9312-000c29cec408.eli - path too long
Sep 23 18:02:37 freenas kernel: GEOM_ELI: Device gptid/64712091-9d54-11e2-9312-000c29cec408.eli created.
Sep 23 18:02:37 freenas kernel: make_dev_physpath_alias: WARNING - Unable to alias gptid/64712091-9d54-11e2-9312-000c29cec408.eli to enc@n5001e6714955800b/type@0/slot@4/elmdesc@Disk_#3_/gptid/64712091-9d54-11e2-9312-000c29cec408.eli - path too long
Sep 23 18:02:37 freenas kernel: GEOM_ELI: Device gptid/27c029db-0c16-11e3-b6f5-002215ab012f.eli created.
Sep 23 18:02:37 freenas kernel: make_dev_physpath_alias: WARNING - Unable to alias gptid/27c029db-0c16-11e3-b6f5-002215ab012f.eli to enc@n5001e6714955800b/type@0/slot@1/elmdesc@Disk_#0_/gptid/27c029db-0c16-11e3-b6f5-002215ab012f.eli - path too long
zpool status
  pool: zfs
state: ONLINE
status: The pool is formatted using a legacy on-disk format.  The pool can
        still be used, but some features are unavailable.
action: Upgrade the pool using 'zpool upgrade'.  Once this is done, the
        pool will no longer be accessible on software that does not support feature
        flags.
  scan: resilvered 1.25T in 12h32m with 0 errors on Sat Aug 24 07:37:39 2013
        zfs                                                ONLINE      0    0    0
          raidz1-0                                          ONLINE      0    0    0
            gptid/27c029db-0c16-11e3-b6f5-002215ab012f.eli  ONLINE      0    0    0
            gptid/622428ec-9d54-11e2-9312-000c29cec408.eli  ONLINE      0    0    0
            gptid/634a7ede-9d54-11e2-9312-000c29cec408.eli  ONLINE      0    0    0
            gptid/64712091-9d54-11e2-9312-000c29cec408.eli  ONLINE      0    0    0
            gptid/65977639-9d54-11e2-9312-000c29cec408.eli  ONLINE      0    0    0
            gptid/66bc5d54-9d54-11e2-9312-000c29cec408.eli  ONLINE      0    0    0
dcevansiii
Was your pool encrypted? I do not believe that mine was and didn't know why the Encryption stuff would be showing up.
zpool status
  pool: zfs
state: ONLINE
        flags.
        zfs                                                ONLINE      0    0    0
I have the same problem on my encrypted pool. Note that my unencrypted pool that is attached to the same physical SAS expander and M1015 doesn't have problems on bootup. I attached my messages to the ticket https://bugs.freenas.org/issues/3183 a few hours ago.
Just waiting for a response from a developer now. But it doesn't appear that anything is wrong, but I'm not sure what the aliases are for, so I could be wrong.
You just responded to a thread from 6 months ago. :)
