8.3.0 rc1 minor gui bug in volume status?
titan_rw
Hi.
Hope this is the right section to post this.
Just noticed something during a scrub.
I'm having issues with 2 hard drives in a raidz2 pool. This is the result of the scrub:
[root@nas /]# zpool status nasbackup
  pool: nasbackup
 state: ONLINE
status: One or more devices has experienced an unrecoverable error.  An
        attempt was made to correct the error.  Applications are unaffected.
   see: http://www.sun.com/msg/ZFS-8000-9P
  scan: scrub repaired 550G in 9h30m with 0 errors on Thu Oct 25 07:52:06 2012
        nasbackup                                       ONLINE       0     0     0
          raidz2-0                                      ONLINE       0     0     0
            gptid/0e6e97ab-1975-11e2-8888-6805ca0a1737  ONLINE       0     0     0
            gptid/0ee79e03-1975-11e2-8888-6805ca0a1737  ONLINE       0     0 8.72M
            gptid/0f6308d1-1975-11e2-8888-6805ca0a1737  ONLINE       0     0     0
            gptid/0fdd4351-1975-11e2-8888-6805ca0a1737  ONLINE       0     0 8.72M
            gptid/1041584c-1975-11e2-8888-6805ca0a1737  ONLINE       0     0     0
            gptid/109396d2-1975-11e2-8888-6805ca0a1737  ONLINE       0     0     0
errors: No known data errors
I would interpret this as 8.72 million checksum errors?
Going to the gui, and checking volume status, only 8 checksum errors show. Is this an issue with the web interface only showing whole numbers?
Not having checked 'zpool status' myself, I might believe that there were only 8 errors, ie, not a huge deal. Whereas 8 million errors is something different.
I didn't see anywhere that this had been posted before, so I apologize if it's been mentioned.
paleoN
That seems suspicious with both drives have the exact same number of errors. How are those to drives connected? What does the SMART info look like on those drives? E.G.:
smartctl -q noserial -a /dev/adaX
I can't speak to the GUI/CLI mismatch part.
titan_rw
Hi..
I'm not all that worried about the pool, or the drives. They were only hooked up for testing.
They are hooked up through esata though. A 2 bay enclosure, and a 4 bay enclosure. What's funny is the 2 drives throwing checksum errors are 2 out of the 4 bay enclosure. I had thought that the 2 bay enclosure was bad, being 2 drives are showing similar (same?) errors. But the 2 in the double bay, and 2 in the quad bay are fine.
The pool is a mismatch of any 1tb drives I had lying around. Like I said, testing purposes only. Of the 6 drives, 1 is a seagate 7200, 3 are samsungs, and 2 are WD Greens. Both 'bad' drives are samsungs though. Here's the smart info on the 2 questionable drives:
ada1:
Model Family:     SAMSUNG SpinPoint F1 DT
Device Model:     SAMSUNG HD103UJ
Firmware Version: 1AA01109
User Capacity:    1,000,204,886,016 bytes [1.00 TB]
Sector Size:      512 bytes logical/physical
ATA Version is:   8
ATA Standard is:  ATA-8-ACS revision 3b
Local Time is:    Thu Oct 25 15:20:14 2012 PDT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
                                        been run.
data collection:                (11884) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        ( 199) minutes.
Conveyance self-test routine
recommended polling time:        (  21) minutes.
SCT capabilities:              (0x003f) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x000f   100   100   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0007   076   076   011    Pre-fail  Always       -       8100
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       315
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       2
  7 Seek_Error_Rate         0x000f   100   100   051    Pre-fail  Always       -       0
  8 Seek_Time_Performance   0x0025   100   100   015    Pre-fail  Offline      -       9885
  9 Power_On_Hours          0x0032   094   094   000    Old_age   Always       -       32803
 10 Spin_Retry_Count        0x0033   100   100   051    Pre-fail  Always       -       0
 11 Calibration_Retry_Count 0x0012   100   100   000    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       309
 13 Read_Soft_Error_Rate    0x000e   100   100   000    Old_age   Always       -       0
183 Runtime_Bad_Block       0x0032   100   100   000    Old_age   Always       -       0
184 End-to-End_Error        0x0033   100   100   099    Pre-fail  Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0022   069   058   000    Old_age   Always       -       31 (Min/Max 13/35)
194 Temperature_Celsius     0x0022   065   057   000    Old_age   Always       -       35 (Min/Max 13/36)
195 Hardware_ECC_Recovered  0x001a   100   100   000    Old_age   Always       -       166291039
196 Reallocated_Event_Count 0x0032   100   100   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   100   100   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x000a   099   099   000    Old_age   Always       -       8611
201 Soft_Read_Error_Rate    0x000a   100   100   000    Old_age   Always       -       0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 0
Warning: ATA Specification requires self-test log structure revision number = 1
# 1  Extended offline    Completed without error       00%     32785         -
# 2  Extended offline    Aborted by host               30%     32631         -
Note: selective self-test log revision number (0) not 1 implies that no selective self-test has ever been run
SMART Selective self-test log data structure revision number 0
Note: revision number not 1 implies that no selective self-test has ever been run
ada2:
ATA Version is:   8
Local Time is:    Thu Oct 25 15:21:23 2012 PDT
                                        was never started.
                                        been run.
data collection:                (11778) seconds.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 197) minutes.
  3 Spin_Up_Time            0x0007   076   076   011    Pre-fail  Always       -       7920
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       90
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       1
  7 Seek_Error_Rate         0x000f   253   253   051    Pre-fail  Always       -       0
  8 Seek_Time_Performance   0x0025   100   100   015    Pre-fail  Offline      -       9802
  9 Power_On_Hours          0x0032   098   098   000    Old_age   Always       -       10303
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       84
190 Airflow_Temperature_Cel 0x0022   067   056   000    Old_age   Always       -       33 (Min/Max 13/37)
194 Temperature_Celsius     0x0022   063   054   000    Old_age   Always       -       37 (Min/Max 13/39)
195 Hardware_ECC_Recovered  0x001a   100   100   000    Old_age   Always       -       221963206
200 Multi_Zone_Error_Rate   0x000a   099   099   000    Old_age   Always       -       4306
No Errors Logged
# 1  Extended offline    Completed without error       00%      9989         -
Nothing jumps out at me. They both have reallocated sectors. But only 1 & 2 each. ada1 has almost 4 years on spin time on it.
Both drives are out of warranty, even if they are bad. They both pass the extended 'long' smart test. Although for ada2, it was 13 days ago. I haven't tried running seatools on them yet.
I'm scrubbing the pool again, just out of curiosity. Only 10% done, but no errors yet.
titan_rw
If it was 8.72 meg, how come the scrub showed 550 gig repaired? 8 megs of bad data on 2 drives wouldn't have caused 550 gigs of scrub repair.
Plus, when you see a number like "2". This is 2 bytes, then? Seems more likely it's "2" checksum errors. I don't know if it's per sector, or zfs 'stripe'.
I'm thinking that 550GB repaired means that at some point you replaced a failed drive and didn't do a scrub of the zpool to restore the data to the new drive added. At least, when I did some drive replacements I saw really high GB/TB values because I was replacing a drive.
If you didn't replace a drive that failed ever for the zpool, did you ever use the array with 1 drive(or more potentially) not connected (or perhaps diffferent drives at different times) and the drive needed to resync with the array? It really sounds like one of your hard drives got out of sync with the zpool somehow and your scrub operation corrected the discrepancy.
titan_rw
But upon replacing a drive, doesn't the resilver handle restoring data to the drive? I've replaced drives in my raidz3 pool, and after the resilver, I ran a scrub. The scrub showed zero repaired.
The pool in question has never been used degraded. Not as far as I'm aware at least.
I just noticed on console that I'm getting timeout errors coming from the controller of 4 drive esata enclosure. Still don't know if it's the drives, the enclosure, or the controller.
I still think the checksum 'stat's are just numbers, not representing megabytes, or anything. Just the total number of checksum errors. To keep the output smaller when the numbers get big, it simply appends the correct number suffix. It just seems that the gui doesn't interpret this correctly.
If you do a hard drive replacement using the GUI I know a resilvering will automatically start. Not sure about command line though. If you wanted to, and this would be stupid, you could stop the resilvering from the command line after replacing a drive from the GUI. Also, if you replace a drive and do a reboot before the resilvering finishes I don't think it will restart automatically.
So there's a few situations where a resilvering may not complete.
If a drive is accidentally unplugged from the system and later reattached FreeNAS will not automatically start resilvering. I don't know how it would be possible for a drive to be detached and then reattached without you either being the cause or knowing of the issue.
In any case the 550GB of data seems to be from a drive that was not in sync with the zpool. Maybe someone else can pipe up with more experience with this or another theory.
titan_rw
I'm pretty sure the 550 gig of repair is from the 2 drives showing checksum errors. When the checksum errors were lower, the repaired number was much lower too. Something happened to those two drives that corrupted a significant portion of them. Yea, replacing a drive via the command line absolutely kicks off a resilver. The drives I did swap, I used the commandline for. "offline", "replace", wait for resilver, then "detach" the old drive.
Anyway, I just thought I'd mentioned the gui anomaly. Not a big deal, but not a true representation of what the cli would tell you.
