macOS Catalina SMB Time Machine not work with FreeNAS-11.3-U3.2
ObiTobi
I would like disable AFP Protocol on my NAS box. But the Timae Machine will not work with SMB for me. Today I updated my FreeNAS from 11.3-U2.1 to U3.2 because SMB BUG, but no like.
Fro my smb4_shares.conf
[Time Machine]
        comment = Time Machine
        read only = no
        fruit:locking = netatalk
        strict locking = auto
        streams_xattr:prefix = user.
        streams_xattr:store_stream_type = no
        vfs objects = fruit streams_xattr shadow_copy_zfs zfs_space ixnas zfsacl
        fruit:metadata = stream
        fruit:resource = stream
        fruit:time machine = yes
        fruit:volume_uuid = b7d40336-7169-4975-bd27-4e3e3b8f9216
        nfs4:chown = true
        nfs4:acedup = merge
        aio write size = 0
        mangled names = illegal
        ea support = false
        kernel oplocks =   no
        oplocks =   no
        level2 oplocks =   no
        blocking locks =   no
        spotlight =  yes
        path = /mnt/zpool02/backup/OSX
Any Idea what I can do?
If I manually change /Library/Preferences/com.apple.TimeMachine.plist from afp to smb, Time Machine mean my share don's support all needed features :(
Samuel Tai
ObiTobi
Thank you, but it chances nothing here :(
I changes also some things for this share but no luck again.
[Time Machine]
        read only = no
        vfs objects = catia fruit streams_xattr
        nfs4:chown = true
        nfs4:acedup = merge
        aio write size = 0
        ea support =  true
        spotlight =  yes
Samuel Tai
Did you restart SMB after your changes?
ObiTobi
@Samuel - please :) Of course.
I ca boot from my Recover Partition and restore all from my SMB Time Machine share, I can connect to this share with finder (go to server) smb://userName@ServerName/Share all this is not a problem. But I I will set my share as TM Volume, TM mean not all Features are supported
Samuel Tai
Hmm. Similar problems over at UnRAID. This post may help:
fruit:time machine max size = 2T
fruit:encoding = native
fruit:metadata = netatalk
fruit:resource = file
fruit:advertise_fullsync = true
Samuel Tai
anodos
Sambassador
[Time Machine]
        read only = no
        nfs4:chown = true
        nfs4:acedup = merge
        aio write size = 0
        ea support = false
        kernel oplocks =   no
        oplocks =   no
        level2 oplocks =   no
        blocking locks =   no
        spotlight =  yes
Looks like SMB share is also an NFS export and so we've automatically disabled some features in SMB that Time Machine requires in order to make the server less likely to encounter integrity issues on the mixed-protocol share. Try removing the NFS export and restarting the SMB service.
ObiTobi
Nope.
/mnt/zpool02/backup <- dataset
/mnt/zpool02/backup/Linux <- NFS export
/mnt/zpool02/backup/OSX <- AFP/ SMB Share
/mnt/zpool02/backup/Windows <- SMB Share
I don't know why FreeNAS writes to all my shares entries like this
nfs4:chown = true
nfs4:acedup = merge
Maybe because I have NFSv4 active or because in last 6 Years I have only updated my system and newer changed something.
anodos
Sambassador
Set the following as auxiliary parameters for the share:
        oplocks =   yes
        level2 oplocks =   yes
Don't bother with trying to turn on spotlight support. We don't compile with it in 11.3.
ObiTobi
It's not helping.
It seems that there are no clear guidelines how the share has to look like and so it works for some people and not for others.
ObiTobi
OK I give up. I've tried so many things. The last one was with these settings but no luck. Whether it is because of my settings or FreeNAS I don't know. It is not nice.
At the moment I have gone back to AFP protocol. Next week I will set up a new machine, I will see how it looks like with Windows Server 2019.
[Time Machine]
        read only = no
        fruit:locking =  none
        vfs objects = catia fruit streams_xattr zfs_space ixnas zfsacl
        nfs4:chown = true
        nfs4:acedup = merge
        aio write size = 0
        ea support =  yes
        fruit:model =  MacSamba
        fruit:aapl =  yes
        oplocks =   no
        kernel oplocks =   no
        level2 oplocks =   no
        blocking locks =   no
EsTaF
[Time Machine]
        read only = no
        nfs4:chown = true
        nfs4:acedup = merge
        aio write size = 0
        ea support =  yes
        fruit:aapl =  yes
        oplocks =   no
        kernel oplocks =   no
        level2 oplocks =   no
        blocking locks =   no
"June 18, 2020"
There're no posts/answers after it.
That says it all. And about FreeNA$ and about window$ server with afp one))
Opensource/Linux is the best way.
EsTaF
About 4 years ago I'd use afp for time machine. But have troubles. Each snapshot was had creating very long time as from scratch.
c77dk
If possible consider upgrading to 12.0-U2.1 - my TMs are just working (now from Big Sur, but also when the systems were Catalina). In 11.3 it was a little hit or miss for my machines, but in 12.x I've had no issues (except a general SMB issue which @anodos quickly patched)
