Machine freezes on add pluggin jail
Oko
I am running FreeNAS 9.2.1.5 amd64. I ruined my Sunday trying to create plugin jail in order to be able to use pkgng to install Monit on my FreeNAS box. Is there a way to create plugin jail from CLI? Is this related to
https://bugs.freenas.org/issues/4180
Thank you.
Joshua Parker Ruehlig
if you're installing monit, I assume you'll be installing it from ports. So you'd want to install a ports jail instead.
D
dlavigne
Guest
Either type of jail would work for this purpose, with plugins jail providing more flexibility.
According to https://bugs.freenas.org/issues/4153 (linked from above ticket), creating the jail without vimage checked should fix the freeze.
Oko
That's what I thought. I was almost 100% sure that I was suppose to use plugins jail. I thought that I had created a jail without VIMAGE but when I checked it appears that I had it. Thanks for the info but I have to admit that after my yesterday experience I am terrified from creating jails on the production system.
D
dlavigne
Guest
There's nothing scary about running jails, they just take some getting used to. Think of it as a pre-installed FreeBSD virtual machine.
Oko
Trying to install Monit from the CLI and not being in the jail plugins jail which was suppose to enable installation for the packages
[root@neill-zfs] /# pkg install monit
The package management tool is not yet installed on your system.
Do you want to fetch and install it now? [y/N]: y
Bootstrapping pkg please wait
_http._tcp.pkg.FreeBSD.org
pkg: fail to extract pkg-static
Oko
Dru I am familiar with concept of jails for the last 7-8 years. I am just scared to run them on FreeNAS after random freeze like above. I have to keep my job and the fastest way to lose it is having to reboot the system and having NFS stale file handles on computing nodes because of it.
That clip from the website is almost always a sign that you didn't run the command from inside a jail. I've gotten that when I thought I was inside a jail and I wasn't. hehe.
Oko
Damn! I misread the documentation.
DANGER! do not use the pkg_add command in a FreeNAS® jail as it will cause inconsistencies in your package management database.
So yes to answer your question. I haven't run pkg install inside the Jail because I read the documentation first just like in the case of plugin jail vs portsjail and I forgot that FreeBSD now has to packaging systems :(
pkg_add is NOT pkg-ng(pkg command).
You shouldn't be using pkg_add since it's being deprecated. You shouldn't be using the old system. ;)
What I'm saying is if you try to use pkg-ng to install a package from FreeNAS itself you'll get the error.
Oko
I realized, I realized but you were faster to pull the trigger :) See above I edited the post.
Oko
Now I am faced with the original problem. Monit is monitoring Jail not FreeNAS system o_O I guess back to square one and more reading.
Oko
Ok it is not as bad as I thought :) Monit reports jail name as a host name but cpu, memory are real system one. If I find to monitor ZFS volume and NFS exports I would be happy camper.
Oko,
Please stop posting in 2 separate threads on this topic. Stick to one thread. Thanks.
Oko
Oko,
You should link the threads if you have admin privileges. Otherwise it is useful for people who are searching the net to see how the issues were resolved.
