LSI SAS HBA and MegaCli
Rand
Hi guys,
is there any way to get MegaCli to work with a LSI SAS HBA?
I cant get it to list my HBAs :/
MegaCli -AdpAllinfo -aALL
Exit Code: 0x01
MegaCli -adpCount
Controller Count: 0.
Exit Code: 0x00
I have seen references that its only working with actual Raid Cards... any alternatives?
Thanks
Edit: I see there is a new binary storcli - anyone tried that on FreeNas yet?
http://lists.freebsd.org/pipermail/freebsd-ports-bugs/2013-June/256473.html
MegaCLI only works with the LSI RAID controllers. You didn't mention what controller you have, but I'm guessing your controller doesn't work with the MegaCLI tool. To be honest, the few users that have found that the MegaCLI works also find that SMART doesn't work, the hard drives don't pass through the controller properly, etc. So I think you should be happy that the MegaCLI tool doesn't work as that would probably mean that your hardware shouldn't be used with FreeNAS. ;)
Rand
Lol, good point.
I am using Dell H310s flashed to IT mode (2008 chipset). I just thought i could play around with Locate but if there are not alternative tools i guess i will actually label the drives with their serial;)
Rand
Ah i found it ...
https://forums.freebsd.org/viewtopic.php?&t=39186
/SAS2IRCU_P16/sas2ircu_freebsd_amd64_rel# ./sas2ircu LIST
LSI Corporation SAS2 IR Configuration Utility.
Version 16.00.00.00 (2013.03.01)
Copyright (c) 2009-2013 LSI Corporation. All rights reserved.
Adapter Vendor Device SubSys SubSys
Index Type ID ID Pci Address Ven ID Dev ID
0 SAS2008 1000h 72h 00h:01h:00h:00h 1028h 1f1ch
1 SAS2008 1000h 72h 00h:02h:00h:00h 1028h 1f1ch
SAS2IRCU: Utility Completed Successfully.
Edit: Locate works but the disc is not blinking;)
So i guess there's more to it than the tool... probably i need a sideband cable connected :p
