Stefan042
- Apr 16, 2021
Hi, I have an old Quanta d51b-2u server with a QCT LSI 3108 card on it.
The OS see's it:
root@truenas[/]# pciconf -lv | less
mrsas0@pci0:3:0:0: class=0x010400 card=0x89c8152d chip=0x005d1000 rev=0x02 hdr=0x00
vendor = 'Broadcom / LSI'
device = 'MegaRAID SAS-3 3108 [Invader]'
class = mass storage
subclass = RAID
but the driver is not loading apparently, so I can't check the RAID status of the two virtual drives (OS drive is 2x 400GB mirrored, Pool1 is 6x 4TB) via the mrsas (which does not seem to be on the disk).
The file boot/loader.conf has this:
# Prefer newer mrsas(4) to mfi(4) for controllers supported by both.
hw.mfi.mrsas_enable="1"
I suspect that my card, 'MegaRAID SAS-3 3108 [Invader]' just isn't supported but I wanted a 2nd opinion on it. Also, if not supported, can I use mfiutil?
Thanks in advance.
The OS see's it:
subclass = RAID
Thanks in advance.
