TheGagne
- Jul 23, 2015
My ZFS system is crashing about once per month due to Watchdog Timeout. Not ideal. Also due to the irregularity of the crashes, it is hard to troubleshoot. I spent a bunch of time trying out how to disable watchdog reboots, but that did not solve the issue (ipmitool mc watchdog get, ipmitool mc watchdog off).
# FreeNAS-9.3-STABLE-201512121950
# from /var/log/messages before system reboot due to watchdog timeout
Aug 8 09:37:41 freenas mfi0: COMMAND 0xfffffe0001330550 TIMEOUT AFTER 975 SECONDS
# I'm using lsi3108 in jbod mode
# some posts of others with these issues point to changing read ahead and drive caching settings as a potential fix.
# https://forums.freenas.org/index.php?threads/lsi-megaraid-sas-9261-8i-timeout-with-write-back.5960/
# suggests drive write cache: disabled (what is default?)
# https://forums.freebsd.org/threads/20658/
# suggests read ahead: adaptive
# neither of those are using 3108 though...
# here's my settings on mfid0
# other thoughts are possibly to update firmware on lsi card or update driver.
# I understand my use of 3108 is non optimal - if I purchase an lsi 9300 12gb hba, will I be able to simply import my pool or will it require drive reformat since they are raid0 formatted?
[root@freenas] ~# mfiutil show adapter
mfi0 Adapter:
Product Name: LSI 3108 MegaRAID
Serial Number:
Firmware: 24.7.0-0026
RAID Levels: JBOD, RAID0, RAID1, RAID5, RAID6, RAID10, RAID50
Battery Backup: not present
NVRAM: 32K
Onboard Memory: 2048M
Minimum Stripe: 64k
Maximum Stripe: 1M# some posts of others with these issues point to changing read ahead and drive caching settings as a potential fix.
[root@freenas] ~# mfiutil cache mfid0
mfi0 volume mfid0 cache settings:
I/O caching: disabled
write caching: write-through
write cache with bad BBU: disabled
drive write cache: default# other thoughts are possibly to update firmware on lsi card or update driver.
