EponymousOne
- Jan 9, 2017
Hi all,
I've got an ASUS P9D-E/4L (latest BIOS) motherboard which has three LSI 9211 card in it (flashed to IT with the P20 ROM & BIOS Package).
All my drives including the boot SSD are connected to these cards and I'm not using the onboard controller. I have enough slots so why not :)
All the drives get passed through to the BIOS as expected.
I have two questions:
1. What is meant by the "Boot Support" option in the Ctrl+C config menu for the cards? There are four options: Disabled, Enabled BIOS Only, Enabled OS Only, Enabled BIOS & OS. I've no idea which one I should select for best FreeNAS compatibility.
2. I have a small problem in that on certain reboots, the cards must detect the drives in a different order as my boot device always changes to the wrong drive - no matter how many times I set it back. Does anyone know why this happens or how to fix/workaround the issue?
Thanks.
Thanks.
