First off i have used FreeNAS since v8 and OpenSolaris before that for my home storage/backup needs so i know enough to be dangerous but not close to a expert either. current set-up is:
motherboard: supermicro X10SL7-F
cpu: e3-1220v3
ram: 16GB EEC
case: 16 bay Supermicro CSE-836E2-R800B
startech reverse sata to sas cables sff-8087 with the lsi 2308 in HBA mode
This has worked fine but I am not really pushing the system with 6 users backing up at the same time or watching a few movies and own cloud in a jail. The school I work at now needs low cost storage and we scored 2 more of these cases for £200 new unused but old stock on ebay :) so if there is a alternative recommendation it must be ATX or E-ATX.
If I recommend the same set-up with 32GB RAM with a intel 4x 1g network card.
Usage would be a few windows shares for shared department files e.g powerpoints, word docs, pdf's, mp3s and video. also a few non critical servers would be moved to ISCSI shares such as our windows deployment server. finally some NFS or SMB shares for archival of ISO installers etc.. plan based on very low remaining budget is to use WD RED drives rather than SAS or 10kSAS as we don’t need colossal IO. No Dedupe as I think 4TBx16 will need more than 32GB in our case as teachers and students move away from paper it is not uncommon to get 1000+ copies of the same pdf even though we keep telling them to put them online.
A) Cope with me stacking the backplanes so 32 drive bays, or would people recommend 2 SANs each with its own motherboard, or a E5 xeon based setup?
B) Pool layout options. I am thinking 1 pool with 4x 4 disk RAIDz1 or 1 pool with 2x 8 disk RAIDz2 as we don’t need the IO of raid10. Next year the second case will be populated giving 8x 4 disk RAIDz1 or 4x 8 disk RAIDz2
pool
|¬ [hd1,hd2,hd3,hd4] Raidz1
|¬ [hd5,hd6,hd7,hd8] Raidz1
|¬ [hd9,hd10,hd11,hd12] Raidz1
|¬ [hd13,hd14,hd15,hd16] Raidz1
vs
pool
|¬ [hd1,hd2,hd3,hd4,hd5,hd6,hd7,hd8] Raidz2
|¬ [hd9,hd10,hd11,hd12,hd13,hd14,hd15,hd16] Raidz2
C) Can anyone see a reason that this set-up and use case for 70 teachers/users would struggle to access there files?
SSD read / write cache would be added net budget year as would the second case or we may use it for replication as backup for the first SAN. may be 10g intel x520.
Sorry for the rambling post but deadline for parts selection is looming and FreeBSD is not often welcome in windows shops so I want to get a sanity check on my plan.
cpu: e3-1220v3
ram: 16GB EEC
pool
vs
pool
