mstang1988
- Aug 20, 2012
My requirements:
ZFS with 1 disk failure (2 total disks totaling 2 to 4 TB usable)
ITX Form Factor
Low TDP and low noise
ECC RAM
Lowest cost for complete solution minus disks
Will be used as an offsite backup of my primary FreeNAS system for critical data (pictures) and a local backup for my parents data as well (pictures and music) which will be offsited to my ZFS system. My ZFS is ZFS 2 disk failure tolerant.
I have plenty of registered ECC RAM dimms (DDR3 and DDR4) sitting around that I can use for free. They are various speeds so I'm sure I'll have something that fits as long as it does not require SO-DIMM form factor.
Suggestions? Any better support of the AMD CPU's and ECC these days? It's been a while since I had a build.
ITX Form Factor
ECC RAM
