LOST ZPOOL, PLEASE HELP
EmENAS
Hi ,
I was working on adding extra storage to my NAS and I didn't unmount one of the drives that I removed and now my data has become inaccessible
Please help me recover HDD1
rs225
Have you tried shutting it off, reconnecting the drive, and then restarting?
EmENAS
root@freenas:/tmp/zfs # zdb -e HDD1
Configuration for import:
vdev_children: 2
version: 5000
pool_guid: 10021509398290906532
state: 0
hostid: 3747601221
hostname: 'freenas.local'
vdev_tree:
type: 'root'
children[0]:
type: 'disk'
guid: 1584505759463818007
whole_disk: 1
metaslab_array: 38
metaslab_shift: 34
ashift: 12
asize: 2998440558592
is_log: 0
create_txg: 4
path: '/dev/gptid/07d0267c-937e-11e7-88dc-001d099cbd06'
children[1]:
type: 'missing'
guid: 0
zdb: can't open 'HDD1': No such file or directory
That's the path for the missing drive
rs225
Is there a second drive you were working with? Perhaps you added it to the pool and didn't realize it?
EmENAS
Yes it was a removable USB that I was trying to add
EmENAS
Yes I removed it and cleared it. I didn't realize that I had mounted the drive to HDD1
rs225
How was it cleared? Was it completely overwritten, or just partition table removed?
Dice
How was the drive added? If it was as a single drive into a single vdev added to the pool, you've effectively wrecked the pool (inc other drive's content) once you removed the drive and wiped it.
EmENAS
it was added using the web gui
rs225
Was it overwritten with random? If so, it does look like it is probably gone. You can try
head -c15000000 /dev/da0 | hexdump -C | grep "0c b1 ba 00"
for a more precise look.
If the USB is gone, your quickest route to any data is going to be something like testdisk 7.0 or other file recovery software. Since your disk was a single element, most files are stored in an intelligible way. File names will be lost. A full ZFS recovery is possible, but not practical in the year 2017. So you may want to set the drive aside after you recover what you can with file recovery.
EmENAS
All right m so there's no way to unmount the drive ?
