Kevin Horton
- Dec 2, 2015
I no longer have write access to AFP shares.  The server is running FreeNAS-9.10.1-U4 (ec9a7d3).  The client is running OS X 10.12.1.  I had write access in the past, but it disappeared sometime in the last week or two (I have been on the road for much of the last two weeks, so wasn't copying anything to the server).
Looking at the permissions on OS X, I see the ownership is listed as Unknown. FreeNAS shows the ownership as the same user (short user name) as on OS X, but looking at the numeric UIDs, I see that they differ (1001 on FreeNAS, and 501 on OS X).
I did rebuild my storage about two weeks ago, replicating everything to a backup pool, then adding a disk and rebuilding the main RAIDZ2 pool to be one disk larger than before, then replicating everything back. I'm wondering if the numeric UID got changed somehow during that process.
Questions:
1. Is it possible that the UID conflict between the server and client is the root cause of my loss of write access?
2. If the UID conflict is the problem, how can I safely change the UID on FreeNAS?
The main folder I use is kwh (my short user name), in the dataset file_server. Below we see the contents of the file_server data set.
The following images show the permissions of the file_server dataset and the AFP permissions.
Thanks,
Kevin
Questions:
freenas# pwd /mnt/pool/file_server freenas# ls -l total 108 drwxrwxrwx 2 root wheel 9 Dec 13 18:26 .AppleDB drwxrwxrwx 2 root shared 2 Mar 29 2016 .AppleDesktop drwxrwxrwt 3 kwh shared 3 Feb 18 2016 .TemporaryItems -rw-r--r-- 1 kwh shared 297 Feb 21 2016 .apdisk drwxr-xr-x 22 kwh kwh 33 Dec 13 18:01 kwh drwxrwxr-x 3 kwh shared 7 Apr 19 2016 shared drwxr-xr-x 3 tmh tmh 4 Aug 6 15:25 tmh freenas# ls -ln total 108 drwxrwxrwx 2 0 0 9 Dec 13 18:26 .AppleDB drwxrwxrwx 2 0 1003 2 Mar 29 2016 .AppleDesktop drwxrwxrwt 3 1001 1003 3 Feb 18 2016 .TemporaryItems -rw-r--r-- 1 1001 1003 297 Feb 21 2016 .apdisk drwxr-xr-x 22 1001 1001 33 Dec 13 18:01 kwh drwxrwxr-x 3 1001 1003 7 Apr 19 2016 shared drwxr-xr-x 3 1002 1002 4 Aug 6 15:25 tmh
	Thanks,
Kevin
