Lost Pools After USB Reinstallion
robotmonkeys
So something happened and my FreeNAS box locked up and I did a hard reset after I couldn't connect to it. After that happened, the has got in a horrible state where the FreeBSD boot prompt just sat there outputting a stream of #s and doing nothing. (I could not find any documentation about what that means, and google just gave me more forum posts were people were asking the same question.) Without any better ideas, I decided to install the USB boot drive.
That fixed the boot problem, but of course it lost my configuration information. I didn't think this would be much of a problem since I could just reimport my pool. Unfortunately I can't seem to figure out how to do this. The webui throws up warnings about how I'm about wipe the disks. (I don't want to do that. I assume the data on them is fine.)
Using the root prompt from the webui, `zpool status` just says 'no pools available' and `zpool import -FX MyPool` says 'no such pool available'
Just to be clear. If I use Auto Import from the gui, the drop down is empty (probably because of the 'no pools available' message above). If I go to manually import the the volumes, I see the partitions, but i can't bring them in as ZFS.
Am I screwed? I don't think I should be.
You shouldn't be.
First, go get a beer and relax! Your data is safe unless you installed over your pool drive or something else is VERY wrong.
Second, does your GUI show any disks if you go to the View Disks window? If it does, does it show the number of disks that you expect to be in the system?
Post your system specs and freenas version. :)
robotmonkeys
It does show all four disks ada0 through ada3.
MB: Asus H871-plus
FreeNas 9.1.1
Is there anything specific you're looking in the system specs? I really think this is just that I'm not using the software correctly.
The four drives were raided 1-0, but I have to admit that I don't remember what was paired with what. It was just the default that the gui picked out. I'm pretty sure not remembering the layout will screw me over, if the raid tries to rebuild.
The irony of course is that this all got screwed up during the first backup. :( Luckily, must of the data could be reassembled if necessary.
DrKK
FreeNAS Generalissimo
naughty naughty naughty....not ECC RAM. :)
Anyway, I agree with CJ, the odds are good that unless you suffered a non-ECC-related catastrophe, you should be OK.
robotmonkeys
I'm still confused on how I'm supposed to proceed, since the most obvious approach says it will destroy the data. How am I supposed to create a pool without having it reinitialize all the disks in the pool. There should be a way to do it, but I'm not familiar with how to do it, and how to do it in a way that informs the gui.
Sorry I didn't respond back. Somehow I missed your reply posts. So far so good.
So you will need to follow the FreeNAS manual for importing a zpool(assuming you had a zpool). doc.freenas.org is the manual.
Can you post the output of zpool import and zpool status?
robotmonkeys
Well that's kind of a problem.
`zpool import` prints nothing, and as I said above, `zpool status` says no pools found.
DrKK
robotmonkeys, you're making it very hard to help you.
Cyberjock wants to issue the command "zpool import" and "zpool status" on your command-line interface, and tell us what it says back to you.
robotmonkeys
Ysu0vqw
I did. Twice. http://imgur.com/Ysu0vqw
DrKK
weird, the line where you said it did nothing was not present when I viewed this thread before...
Sorry.
Well I assume CJ has some ideas...
Umm... something is VERY wrong.
Post the output of:
camcontrol devlist
gpart status
Are you running in a VM? Post your hardware specs too please.
robotmonkeys
1) This is not in a VM.
2) The hardware specs are in post 3 (after which DrKK flames me for not having ECC ram) Again, if there's something specific hardware-wise you want to know about, I'll post more but I think the MB info should be enough.
3) Here are the outputs of the commands
[root@freenas ~]# camcontrol devlist
<ST3000DM001-1CH166 CC24>          at scbus0 target 0 lun 0 (ada0,pass0)
<ST3000DM001-1CH166 CC24>          at scbus1 target 0 lun 0 (ada1,pass1)
<ST3000DM001-1CH166 CC24>          at scbus2 target 0 lun 0 (ada2,pass2)
<ST3000DM001-1CH166 CC24>          at scbus3 target 0 lun 0 (ada3,pass3)
< USB DISK 2.0 PMAP>              at scbus4 target 0 lun 0 (pass4,da0)
[root@freenas ~]# gpart status
  Name  Status  Components
ada0p1      OK  ada0
ada0p2      OK  ada0
ada1p1      OK  ada1
ada1p2      OK  ada1
ada2p1      OK  ada2
ada2p2      OK  ada2
ada3p1      OK  ada3
ada3p2      OK  ada3
da0s1      OK  da0
da0s2      OK  da0
da0s3      OK  da0
da0s4      OK  da0
da0s1a      OK  da0s1
This is the correct number of HDDs, and the partitions don't look wrong. Each one is a 2GB swap, followed by a 2.7TB zfs partition
How much RAM do you have installed? Are you using the x86 or x64 version(please check.. some people install the wrong version and don't realize it).
DrKK
Sir, your threshold for considering yourself "flamed" seems quite low. :)
Post the output of gpart list too.
Something fishy is going on here. Normally if zpool import doesn't work that means you are in SERIOUS trouble. Normally this would also be a time to see you have no disk partitions. But since your disk partitions are there and look healthy, it's a little confusing.
robotmonkeys
It is very odd. That's why I'm here.
It's running FreeNAS-9.1.1-RELEASE-x64 (a752d35)
16GB ram
Geom name: ada0
modified: false
state: OK
fwheads: 16
fwsectors: 63
last: 5860533134
first: 34
entries: 128
scheme: GPT
Providers:
1. Name: ada0p1
  Mediasize: 2147483648 (2.0G)
  Sectorsize: 512
  Stripesize: 4096
  Stripeoffset: 0
  Mode: r1w1e1
  rawuuid: f65fb0dd-49b2-11e3-a673-ac220b4dc13d
  rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b
  label: (null)
  length: 2147483648
  offset: 65536
  type: freebsd-swap
  index: 1
  end: 4194431
  start: 128
2. Name: ada0p2
  Mediasize: 2998445412352 (2.7T)
  Sectorsize: 512
  Stripesize: 4096
  Stripeoffset: 0
  Mode: r0w0e0
  rawuuid: f678441a-49b2-11e3-a673-ac220b4dc13d
  rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b
  label: (null)
  length: 2998445412352
  offset: 2147549184
  type: freebsd-zfs
  index: 2
  end: 5860533127
  start: 4194432
Consumers:
1. Name: ada0
  Mediasize: 3000592982016 (2.7T)
  Sectorsize: 512
  Stripesize: 4096
  Stripeoffset: 0
  Mode: r1w1e2
Geom name: ada1
modified: false
state: OK
fwheads: 16
fwsectors: 63
last: 5860533134
first: 34
entries: 128
scheme: GPT
Providers:
1. Name: ada1p1
  Sectorsize: 512
  Stripesize: 4096
  Stripeoffset: 0
  Mode: r1w1e1
  rawuuid: fb00bdbf-49b2-11e3-a673-ac220b4dc13d
  label: (null)
  length: 2147483648
  offset: 65536
  type: freebsd-swap
  index: 1
  end: 4194431
  start: 128
2. Name: ada1p2
  Sectorsize: 512
  Stripesize: 4096
  Stripeoffset: 0
  Mode: r0w0e0
  rawuuid: fb19f90e-49b2-11e3-a673-ac220b4dc13d
  label: (null)
  offset: 2147549184
  type: freebsd-zfs
  index: 2
  end: 5860533127
  start: 4194432
Consumers:
1. Name: ada1
  Sectorsize: 512
  Stripesize: 4096
  Stripeoffset: 0
  Mode: r1w1e2
Geom name: ada2
modified: false
state: OK
fwheads: 16
fwsectors: 63
last: 5860533134
first: 34
entries: 128
scheme: GPT
Providers:
1. Name: ada2p1
  Sectorsize: 512
  Stripesize: 4096
  Stripeoffset: 0
  Mode: r1w1e1
  rawuuid: ffcc9abf-49b2-11e3-a673-ac220b4dc13d
  label: (null)
  length: 2147483648
  offset: 65536
  type: freebsd-swap
  index: 1
  end: 4194431
  start: 128
2. Name: ada2p2
  Sectorsize: 512
  Stripesize: 4096
  Stripeoffset: 0
  Mode: r0w0e0
  rawuuid: ffe52834-49b2-11e3-a673-ac220b4dc13d
  label: (null)
  offset: 2147549184
  type: freebsd-zfs
  index: 2
  end: 5860533127
  start: 4194432
Consumers:
1. Name: ada2
  Sectorsize: 512
  Stripesize: 4096
  Stripeoffset: 0
  Mode: r1w1e2
Geom name: ada3
modified: false
state: OK
fwheads: 16
fwsectors: 63
last: 5860533134
first: 34
entries: 128
scheme: GPT
Providers:
1. Name: ada3p1
  Sectorsize: 512
  Stripesize: 4096
  Stripeoffset: 0
  Mode: r1w1e1
  rawuuid: 04781754-49b3-11e3-a673-ac220b4dc13d
  label: (null)
  length: 2147483648
  offset: 65536
  type: freebsd-swap
  index: 1
  end: 4194431
  start: 128
2. Name: ada3p2
  Sectorsize: 512
  Stripesize: 4096
  Stripeoffset: 0
  Mode: r0w0e0
  rawuuid: 04910c09-49b3-11e3-a673-ac220b4dc13d
  label: (null)
  offset: 2147549184
  type: freebsd-zfs
  index: 2
  end: 5860533127
  start: 4194432
Consumers:
1. Name: ada3
  Sectorsize: 512
  Stripesize: 4096
  Stripeoffset: 0
  Mode: r1w1e2
Geom name: da0
modified: false
state: OK
fwheads: 255
fwsectors: 63
last: 15248831
first: 63
entries: 4
scheme: MBR
Providers:
1. Name: da0s1
  Mediasize: 988291584 (942M)
  Sectorsize: 512
  Stripesize: 0
  Stripeoffset: 32256
  Mode: r1w0e1
  attrib: active
  rawtype: 165
  length: 988291584
  offset: 32256
  type: freebsd
  index: 1
  end: 1930319
  start: 63
2. Name: da0s2
  Sectorsize: 512
  Stripesize: 0
  Stripeoffset: 988356096
  Mode: r0w0e0
  rawtype: 165
  length: 988291584
  offset: 988356096
  type: freebsd
  index: 2
  end: 3860639
  start: 1930383
3. Name: da0s3
  Mediasize: 1548288 (1.5M)
  Sectorsize: 512
  Stripesize: 0
  Stripeoffset: 1976647680
  Mode: r0w0e0
  rawtype: 165
  length: 1548288
  offset: 1976647680
  type: freebsd
  index: 3
  end: 3863663
  start: 3860640
4. Name: da0s4
  Mediasize: 21159936 (20M)
  Sectorsize: 512
  Stripesize: 0
  Stripeoffset: 1978195968
  Mode: r1w1e2
  rawtype: 165
  length: 21159936
  offset: 1978195968
  type: freebsd
  index: 4
  end: 3904991
  start: 3863664
Consumers:
1. Name: da0
  Mediasize: 7807401984 (7.3G)
  Sectorsize: 512
  Mode: r2w1e4
Geom name: da0s1
modified: false
state: OK
fwheads: 255
fwsectors: 63
last: 1930256
first: 0
entries: 8
scheme: BSD
Providers:
1. Name: da0s1a
  Mediasize: 988283392 (942M)
  Sectorsize: 512
  Stripesize: 0
  Stripeoffset: 40448
  Mode: r1w0e1
  rawtype: 0
  length: 988283392
  offset: 8192
  type: !0
  index: 1
  end: 1930256
  start: 16
Consumers:
1. Name: da0s1
  Sectorsize: 512
entries: 8
scheme: BSD
Providers:
1. Name: da0s1a
  Sectorsize: 512
  Stripesize: 0
  Stripeoffset: 40448
  Mode: r1w0e1
  rawtype: 0
  length: 988283392
  offset: 8192
  type: !0
  index: 1
  end: 1930256
  start: 16
Consumers:
1. Name: da0s1
  Sectorsize: 512
  Stripesize: 0
  Stripeoffset: 32256
  Mode: r1w0e1
DrKK
OK, well, "flamed", in a forum setting, implies the use of considerable vitriol and effort in deconstructing your intelligence and value as a human being. I was merely clicking my tongue. Doesn't even rise to the level of "chastise" much less "flame". But OK. :)
Try these commands...
sysctl vfs.zfs.vdev.larger_ashift_disable=1
zpool import -D -R /mnt yourpoolname
If that doesn't import do:
zpool import
zpool export yourpoolname
Edit: zpool import -D -R /mnt yourpoolname might throw an error, then you'll have to add -f
