Ashley Drees
 - Oct 6, 2015
I have FreeBSD 11.2-STABLE (FreeNAS.amd64) #0 r325575+9a3c7d8b53f(HEAD)
On a dell 2900 with 24 gig memory with 8 2DB drives on an Intel 63XXESB2 SATA300 controller and Broadcom BCM57412 NetXtreme-E 10Gb Ethernet + the usual built in NIC
Sometime between me installing Broadcom BCM57412 NetXtreme-E 10Gb Ethernet and now - I started losing the GUI - first time it went I blamed myself thinking I had done something dull on the command line that locked it up - I rebooted from the command line, this has now happened again and this time i suspect the card/driver.
An error in the nginx log shows... May 7 12:25:29 server.domain.tld nginx: 2019/05/07 12:25:29 [error] 57255#100628: *109 upstream timed out (60: Operation timed out) while reading response header from upstream, client: 192.168.9.22, server: localhost, request: "GET /websocket HTTP/1.1", upstream: "http://127.0.0.1:6000/websocket", host: "192.168.9.13" . - which looks like the web socket attached to the NIC with ip 192.168.9.13 seems to be broken in some way.
192.168.9.22 is my workstation trying to get to the GUI.
I tried to restart django and nginx - but that does not help, when i restarted the whole thing it came back till netinfo ran.
I think I have something happening with the 10gig NIC card somehow.
the unused port gives
bnxt1: flags=8802<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=e507bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,LRO,VLAN_HWFILTER,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6>
ether 00:0a:f7:ea:17:21
hwaddr 00:0a:f7:ea:17:21
media: Ethernet autoselect (Unknown <full-duplex,rxpause,txpause>)
status: no carrier
Nothing plugged in - however the active port
ifconfig bnxt0
bnxt0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=a500b9<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,VLAN_HWFILTER,VLAN_HWTSO,RXCSUM_IPV6>
ether 00:0a:f7:ea:17:20
hwaddr 00:0a:f7:ea:17:20
inet 192.168.9.13 netmask 0xffffff00 broadcast 192.168.9.255
Hangs at that point, however, our shared resources are still available afp/smb/ssh over that fibre connection - so i don't want to force a reboot at this point - also the console seems to have frozen.
Ah... one other thing, its uplink is a UniFi Switch 16XG, which does not seem to be having any issues.
However the console shows "bnxt0 TX(2) desc avail = 21. pdix = 172" with various pdix values 173, 102, 222 and 7
The console is also locked up.
status: no carrier
ifconfig bnxt0
