zombiezafer
- Nov 29, 2021
I have a SUN FIRE X4470 SERVER with intel 82599ES chipset dual port 10Gbit Ethernet. Windows was installed on it and the cards were working. After I installed Truenas Core 12.0 U6.1 I could not figure out to make 10Gbit ports UP. I can see that cards are there but ports cannot get Up. I've changed the ports on the switch, SFPs and FC cable. But still the ports are not up. I tried to make a lagg port but it didn't help.
Here is pciconf and dmesg and ifconfig outputs related with 10GB card ports.
root@truenas[/tmp/driver]# pciconf -lv | grep -B4 network
ix0@pci0:193:0:0: class=0x020000 card=0x7b11108e chip=0x10fb8086 rev=0x01hdr=0x00
vendor = 'Intel Corporation'
device = '82599ES 10-Gigabit SFI/SFP+ Network Connection'
class = network
subclass = ethernet
ix1@pci0:193:0:1: class=0x020000 card=0x7b11108e chip=0x10fb8086 rev=0x01hdr=0x00
class = network
root@truenas[/tmp/driver]# dmesg | grep ix0
ix0: <Intel(R) X520 82599ES (SFI/SFP+)> mem 0xfbc00000-0xfbc7ffff,0xfbbfc000-0xfbbfffff irq 54 at device 0.0 on pci13
ix0: Using 2048 TX descriptors and 2048 RX descriptors
ix0: Using 16 RX queues 16 TX queues
ix0: Using MSI-X interrupts with 17 vectors
ix0: allocated for 16 queues
ix0: allocated for 16 rx queues
ix0: Ethernet address: 00:1b:21:8e:3b:1c
ix0: PCI Express Bus: Speed 5.0GT/s Width x8
ix0: eTrack 0x000118c9 PHY FW V65535
root@truenas[/tmp/driver]# dmesg | grep ix1
ix1: <Intel(R) X520 82599ES (SFI/SFP+)> mem 0xfbd80000-0xfbdfffff,0xfbd7c000-0xfbd7ffff irq 61 at device 0.1 on pci13
ix1: Using 2048 TX descriptors and 2048 RX descriptors
ix1: Using 16 RX queues 16 TX queues
ix1: Using MSI-X interrupts with 17 vectors
ix1: allocated for 16 queues
ix1: allocated for 16 rx queues
ix1: Ethernet address: 00:1b:21:8e:3b:1d
ix1: PCI Express Bus: Speed 5.0GT/s Width x8
ix1: eTrack 0x000118c9 PHY FW V65535
root@truenas[/tmp/driver]# ifconfig
igb0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: igb0
options=e527bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,LRO,WOL_MAGIC,VLAN_HWFILTER,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6>
ether 00:21:28:a5:6f:f8
inet 192.168.59.106 netmask 0xffffff00 broadcast 192.168.59.255
media: Ethernet autoselect (1000baseT <full-duplex>)
status: active
igb1: flags=8802<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500
ether 00:21:28:a5:6f:f9
status: no carrier
nd6 options=1<PERFORMNUD>
igb2: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: igb2
ether 00:21:28:a5:6f:fa
inet 192.168.59.107 netmask 0xffffff00 broadcast 192.168.59.255
status: active
igb3: flags=8802<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500
ether 00:21:28:a5:6f:fb
status: no carrier
ix0: flags=8802<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=e53fbb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,LRO,WOL_UCAST,WOL_MCAST,WOL_MAGIC,VLAN_HWFILTER,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6>
ether 00:1b:21:8e:3b:1c
status: no carrier
ix1: flags=8802<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500
ether 00:1b:21:8e:3b:1d
status: no carrier
options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x7
groups: lo
pflog0: flags=0<> metric 0 mtu 33160
groups: pflog
class = network
subclass = ethernet
class = network
description: igb0
status: active
status: no carrier
description: igb2
status: active
status: no carrier
status: no carrier
status: no carrier
groups: lo
groups: pflog
