loss of network connection on reboot
Henning Kessler
I am running a FreeNAS Mini with 11.1-U5 and tried to update 11.1-U6. After the reboot the machine lost its network connectivity (fixed IP, both NICs linked via LACP) I managed to login via Console and deleted the link aggregation interface "lagg0" created it again and then configured the interface as before. After this the network worked fine. I thought the issue maybe could be a problem with the update and booted back to 11.1-U5. On reboot the network connectivity was lost again.
Any idea what is happening here? could this be a problem with an VNET configiured iocage jail that I started to use under 11.1-U5?
here is the current working output of ifconfig
igb0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
	options=6403bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6>
	ether d0:50:99:c3:11:a3
	hwaddr d0:50:99:c3:11:a3
	media: Ethernet autoselect (1000baseT <full-duplex>)
	status: active
igb1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
	hwaddr d0:50:99:c3:11:a4
	status: active
	options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
	inet6 ::1 prefixlen 128
	inet6 fe80::1%lo0 prefixlen 64 scopeid 0x3
	groups: lo
	ether 02:d7:a0:8d:34:00
	groups: bridge
	member: vnet0:2 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
			ifmaxaddr 0 port 6 priority 128 path cost 2000
lagg0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
	inet 10.99.10.33 netmask 0xffffff00 broadcast 10.99.10.255
	inet 10.99.10.35 netmask 0xffffff00 broadcast 10.99.10.255
	status: active
	groups: lagg
	laggproto lacp lagghash l2,l3,l4
	laggport: igb0 flags=1c<ACTIVE,COLLECTING,DISTRIBUTING>
	laggport: igb1 flags=1c<ACTIVE,COLLECTING,DISTRIBUTING>
vnet0:2: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
	description: associated with jail: dc01
	options=8<VLAN_MTU>
	ether 02:ff:60:8a:5c:39
	hwaddr 02:26:90:00:06:0a
	nd6 options=1<PERFORMNUD>
	status: active
	groups: epair
any help or hint would great.
Henning
Chris Moore
What is your reason for using LACP? If you don't have a lot of clients accessing the NAS simultaneously, there is no reason to have this configured and it is causing problems. Just use a single network interface.
Henning Kessler
Hi Chris,
thanks for your suggestion but that Mini actually is in use by a couple of graphic designers. At least 2-3 of them are using it concurrently. It would be great if I could keep up with link-aggregated interfaces ;-).
Regards
Henning
Henning Kessler
changed the type of link aggregation from LACP to load balance did not help so it seams to be a general link aggregation problem...
Henning Kessler
okay the problem indeed is solved by deleting the link aggregation and using only a single interface.
But giving up the link aggregation make me sad. I know I could get a 10Gbit Interface but then I would need to get new switches as well and even then link aggregation still make sense when used as failover solution on some stacked switches....
isn't there a different solution?
Chris Moore
You could submit a bug report explaining the details of the situation, perhaps it would prompt the developers to work on this problem.
Henning Kessler
Hi Chris, I guess you are right. I have converted the VNET jail to a "normal" jail (vnet="off") and deleted the two tunables
cloned_interfaces="bridge0"
ifconfig_bridge="addm lagg0 up"
and now there are no more network issues after the restart.
Chris Moore
There have been problems with using LAG and VNET since 9.3 (or earlier) and I know I was right, that is why I said it.
I tried doing it years ago, had problems getting reliable functionality and I remember looking through the forums for advice at the time. Some things have not been fixed and might never get fixed. If I recall, it is a fault that is inherited from the upstream OS, so if you really wanted it fixed, you would probably need to file a bug report with the FreeBSD project instead of filing one with the FreeNAS team.
