Hi all,
I just acquired a JBOD which was made in 2011, it has 60 2TB 7.2k SATA disks but using SATA-to-SAS adapters on each disk. There are two IO modules on the enclosure, each module offer 4 SFF-8088 ports, the speed of these SAS port is 3Gb/s. It were connected to a controller box equiped with 2 LSI SAS3160E HBA cards, running some kind of software raid. When connected the LSI HBA cards presents 120 disks to the controller(but actually only 60 disks, e.g. sdcc and sddj is the same disk). I have wiped out the software raid and managed to run zfs on it. If I run two sas cables from one HBA card to two IO modules, the write bandwidth is 1100MB/s. If I run two sas cables from two HBA cards to two IO modules, the write bandwidth is 1445MB/s.
Is it possible to max out the bandwith by using a somewhat newer controller box(used servers are so cheap anyway)? I'm looking at the DELL R620 1U box, equiped with a LSI SAS9207-8e HBA card. The R620 has PCIe-3.0 slots, and SAS 9207-8e is 6Gb/s, will I get better bandwidth?
suggestions appreciated. Thanks.
