Mannekino
- Nov 14, 2012
I'm trying to learn more about the various network settings for jails but I'm not getting a lot from the documentation unfortunately. I find the settings confusing and I'm hoping for a more layman explanation of the options. I currently have one jail running with Transmission and I'm using DHCP for this and it seems to be working well. I created a second test jail because I want to understand the networking options better and I would like to have a jail with a static IP address also.
Here is the
And this is the ifconfig from my current test jail:
Questions about "Basic Properties"
Right now my test jail is configured as follows and I think this is the right way to go about it for using a static IP address but I'm not sure.
I have the following questions regarding this section of the configuration:
When I get to the "Network properties" I get completely lost unfortunately. I've read the tool tips and manual but I don't really understand.
Thank you in advance.
Here is the
ifconfig output of my FreeNAS server, it's running on bare metal and I have one psychical interface configured em1.Code:
em0: flags=8c02<BROADCAST,OACTIVE,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=209b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC>
ether 00:25:90:74:57:e1
hwaddr 00:25:90:74:57:e1
media: Ethernet autoselect
status: no carrier
em1: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=2098<VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC>
ether 00:25:90:74:57:e0
hwaddr 00:25:90:74:57:e0
inet 192.168.178.3 netmask 0xffffff00 broadcast 192.168.178.255
media: Ethernet autoselect (1000baseT <full-duplex>)
status: active
options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x3
groups: lo
ether 02:dc:dd:47:50:00
nd6 options=1<PERFORMNUD>
groups: bridge
member: vnet0:7 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 6 priority 128 path cost 2000
member: vnet0:4 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 4 priority 128 path cost 2000
member: em1 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 2 priority 128 path cost 20000
vnet0:4: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: transmission
options=8<VLAN_MTU>
ether 02:ff:60:03:aa:46
hwaddr 02:b7:d0:00:04:0a
status: active
groups: epair
vnet0:7: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: test
options=8<VLAN_MTU>
ether 02:ff:60:ae:1b:75
hwaddr 02:b7:d0:00:06:0a
status: active
groups: epairAnd this is the ifconfig from my current test jail:
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
groups: lo
epair0b: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether 02:ff:60:ae:1b:76
hwaddr 02:b7:d0:00:07:0b
inet 192.168.178.5 netmask 0xffffff00 broadcast 192.168.178.255
status: active
groups: epairQuestions about "Basic Properties"
- From what I read it is preferred to enable
VNETfor a jail. I'm still not 100% sure on what this does exactly. Is this similar to, lets say, setting up a "bridged" network in VMware Workstation or VirtualBox which I'm using on my workstation? - What is the best interface to select? I have the options listed below:
em0: this would be my primary psychical network interface that is currently not in useem1: this would be my secondary psychical network interface that is connected to my home routerbridge0: I don't fully understand how this differs from thevnet0option, hoping to learn what the difference is between this and the last interface.vnet0: this interface appears when you check theVNETbox above. Is this the preferred interface?
- I'm assuming when you enable
VNETfor at least one jail thebridge0device is created on the FreeNAS server and under that "bridge device" all the virtual network interfaces are created for the jails, am I getting this right conceptually? - Am I correct to think that the
epair0bnetwork interface inside the jail is thevnet0:7interface outside of the jail, on the FreeNAS server? - It states that you need to enable the
Berkeley Packet Filterwhen enabling DHCP. I assume it's best to not select it if you are using a static IP address configuration?
- When I switch the network interface from
vnet0tobridge0the text in "interfaces" remains the samevnet0:bridge0. Shouldn't this text change also depending on the network interface I selected in "Basic Properties"? Why is it the same text for both thevnet0andbridge0interfaces. This goes back to my earlier question about the difference between those two. - The checkbox for
ip4.saddrselis always checked whether or notVNETis selected. The tool tip says "Only available when the jail is not configured to use VNET". If I selectVNETthe box is still ticked, why is this? - And lastly, why are there two mac-addresses listed in the box
vnet0_mac? I assume these are two mac-addresses separated by a space? Why are there two?
