WalterWampe
- Mar 17, 2017
Hello pros out there,
as a beginner I come to you with a question about usability, security and because I am looking to the best solution.
I spend the last weeks gathering information and reading manuals and threads and now I am stuck with my initial concept and am not sure whether I should just let go and go for a better solution.
I had the idea of getting my own NAS after having bought my 10th or so external HDD to save my photos and gopro videos on.
I then came to the idea of also using it also as a timemachine backup drive and for my iphone/ipad backups.
Finally if its already there, I thought I could use it to store more random stuff which accumulates slowly on my laptop on there.
So most of the data is not everyday use.
My plan is to use FreeNAS (not sure if Corral or 9.10 yet after testing Corral today) as my mainNAS/backupNAS system.
For my MainNas backup, but only as a temporary solution (until a friend of mine gets his FreeNAS too and we start to replicate each others snapshots as long term plan, maybe in 6 months or so) I wanted to use a second FreeNAS system (backupNas) just for replication of my snapshots, both running as VMs on my hardware.
To do so I run an esxi host on my hardware:
1. supermicro X11SSM-F board with VT-d
2. one m1018 controller HBA LSI Megaraid 9212-4i 6G in IT Mode with passthrough
3. 16GB ECC RAM Samsung M391A2K43BB1 DDR4-2133 DIMM
4. SSD containing my VMs
5. USB stick 16 GB Mach Xtreme Technology MX-ES to boot esxi
6. 2x2TB HDD WD Red WD20EFRX Intellipower
7. 2x4TB HDD Seagate IronWolf NAS (1x2TB and 1x4TB for mainNas, 1x2TB and 1x4TB as backupNas)
8. Intel Core i3 6100 2x 3.70GHz
In the future I want to add more VMs, like for home automation and dedicated servers. Until now I have a factorio headless server running via ubuntu on another VM. Therefore actual VMs:
1. mainNAS
2. backupNAS
3. ubuntu/factorio
Every whole disk is configured a single stripe zfs pool for mainNAS and backupNAS containing sub datasets:
Last line of defence for all of my data will be my external HDDs still, as I wont wipe them, but I am planning to duplicate my photo data maybe once a year onto them.
The plan is to let my mainNas do snapshots once a day for my data on my 2TB drive(iDevice backups, timemachine...) and once a week for my photos and gopro videos on my 4TB drive as I wont add data too frequently there, and replicate the snapshots to my backupNas to have the data still if one of my main drives fails or gets wiped somehow else.
I also created an emergency freenas stick to boot from if my esxi fails which enables me to access my data on my mainNAS.
Now for my question on the whole setup:
A) How would you given my current hardware resources set up your system and/or configure it?
B) Is this even a real backup solution or am I missing something here (despite from having all disks running on the same host system)?
C) Does there has to be the second (backupNAS) FreeNAS system for replication, as it can't do SMART tests and saves its data in vmware containers on the "backup HDDs"? Or should/can I just use any ubuntu system with ssh to replicate?
D) As corral offers the possibility to run VMs: is there a solution to run a VM with passthrough of my m1018 on there to backup my data to somehow?
I am not sure which direction to go and invest my time into, so I am here to hear your opinions.
Thank you very much in advance for your inputs, I really appreciate.
Walter
1. mainNAS
2. backupNAS
3. ubuntu/factorio
- MainNAS: 4TBDisk: 4TB Dataset "photos and videos", 2TBDisk: 2TB Datasets "timemachine", "data", "itunes", "iphoto"
- BackupNAS: 4TBDisk: 4TB Dataset containing 4TB snapshot replications, 2TBDisk: 2TB Dataset containing 2TB snapshot replications
Walter
