Hmm... Just curious.. if the console screen was capable of being password protected ... never mind... dont want to argue over this..
I will look and see how to hide the console menu... just seems to me that if a person was at the console menu and chose an option then there would be a security feature that would then next ask for a password to "unlock" the option for editing... just saying.
Thank you for your input.. it is appreciated as always!
Sincerely,
Kell
As mentioned, not directly.
However, if you disable the console menu as stated, you can then login as root, and launch the console menu.  Accomplishes the same thing, albeit in a different way.
After logging in as root, use "python /etc/netcli", or simply launch "/etc/netcli" directly, as it seems to have the 'sheebang' magic to launch python itself.  However, once launched, I'm not sure the best way to kill it.  Maybe launching it this was is not the correct way of doing it.
