Hi all, I've been experimenting with FreeNAS for a few days now and I'm pleasantly surprised about it's functionalities!
My setup:
RAM: CORSAIR DDR3/1866 2x4GB DIMM Vengeance CL9 DDR3 - 240 pin - 1,5V - CL9 - 2x 4GB Kit
MOBO: GIGABYTE FM2 GA-F2A75M-D3H AMD A75 - 4 x DDR3 - SATA600/USB3.0
CPU: AMD A10 5800K Black Edition FM2 3.8GHz Quad-Core
HDD: 2 x western digital RED 3TB 7200rpm (I still have 3 spare drives of 1,5tb; 320gb and 160gb but I'll add those later on)
SSD: sandisk 128gb
PSU: antec continuous power 520watt
I know the CPU is overpowered but I initially didn't plan on creating a fileserver with FreeNAS.
The setup described is actually my HTPC which is sitting under my TV and is pretty silent actually!
I just installed windows 8 on the 128GB SSD and started my experiments with FreeNAS using virtual box.
With some minor tweaks here and there I could enable raw disk access for the VM but windows is not letting me at the moment.
So I started of with simple virtual hard disks, virtual box and also vmware can't handle virtual drives larger than 3tb.
So I split every drive up in parts of 1tb and made those available to FreeNAS.
So I created a raidz2 array of those 6 disks and ended up with a volume of 3tb in size.
I then created my windows CIFS share and started some experimenting/benchmarking.
What I'm seeing now is that I'm only getting 35MB/s when I'm writing to the fileserver.
Reads are a little better ranging from 40 to 45MB/s.
I know that a VM can't beat a dedicated fileserver but I'm just wondering what kinds of speeds other people are recording using a virtual fileserver.
Playing around with the ZFS configuration of the drives doesn't help either.
Tried striping all 6 virtual hard drives and mirroring them, all setups have the same result.
Enabled host I/O cache
added a ZIL (virtual drive on the SDD) for logging, marked the virtual drive as SDD in virtual box.
Followed the 1GB of RAM per TB of storage rule
So I'm thinking virtual box is really being the bottleneck here...
Next thing I'm gonna try is enabling raw disk access but I have to solve a few errors first, I'm getting the VERR_ACCESS_DENIED error.
Looking forward to your thoughts/statistics or benchmarks!
			My setup:
SSD: sandisk 128gb
