EsTaF
- Sep 20, 2013
Всем доброго
После обновления FreeNAS 11.2 u1 до u2 невозможно запустить ни один из jail дополнений.
ошибка UnboundLocalError: local variable 'bridge_cmd' referenced before assignment
развернуто
Локальная переменная ссылается до присваивания. Присваивания чего?
Нужно как-то все править после обновлений?
развернуто
Error: concurrent.futures.process._RemoteTraceback:
File "/usr/local/lib/python3.6/concurrent/futures/process.py", line 175, in _process_worker
r = call_item.fn(*call_item.args, **call_item.kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 128, in main_worker
res = loop.run_until_complete(coro)
File "/usr/local/lib/python3.6/asyncio/base_events.py", line 468, in run_until_complete
return future.result()
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 88, in _run
return await self._call(f'{service_name}.{method}', serviceobj, methodobj, params=args, job=job)
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 81, in _call
return methodobj(*params)
File "/usr/local/lib/python3.6/site-packages/middlewared/schema.py", line 668, in nf
return f(*args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/jail.py", line 581, in start
iocage.start()
File "/usr/local/lib/python3.6/site-packages/iocage_lib/iocage.py", line 1663, in start
callback=self.callback
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_start.py", line 66, in __init__
self.__start_jail__()
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_start.py", line 415, in __start_jail__
vnet_err = self.start_network(vnet)
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_start.py", line 598, in start_network
err = self.start_network_interface_vnet(nic, net_configs, jid)
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_start.py", line 624, in start_network_interface_vnet
membermtu = self.find_bridge_mtu(bridge)
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_start.py", line 975, in find_bridge_mtu
su.check_call(bridge_cmd, stdout=su.PIPE, stderr=su.PIPE)
The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 165, in call_method
result = await self.middleware.call_method(self, message)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1141, in call_method
return await self._call(message['method'], serviceobj, methodobj, params, app=app, io_thread=False)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1078, in _call
return await self._call_worker(serviceobj, name, *args)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1105, in _call_worker
job,
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1036, in run_in_proc
return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1021, in run_in_executor
