Makaveli6103
- Mar 18, 2012
I was reading the post on the WD Red and decided to check out my other drives.
Should I be worried about this?
Model Family: SAMSUNG SpinPoint F4 EG (AF) Device Model: SAMSUNG HD204UI Serial Number: LU WWN Device Id: Firmware Version: 1AQ10001 User Capacity: 2,000,398,934,016 bytes [2.00 TB] Sector Size: 512 bytes logical/physical Rotation Rate: 5400 rpm Device is: In smartctl database [for details use: -P show] ATA Version is: ATA8-ACS T13/1699-D revision 6 SATA Version is: SATA 2.6, 3.0 Gb/s Local Time is: Sun Mar 23 23:03:18 2014 CDT 1 Raw_Read_Error_Rate 0x002f 100 100 051 Pre-fail Always - 19 2 Throughput_Performance 0x0026 055 055 000 Old_age Always - 18204 3 Spin_Up_Time 0x0023 068 066 025 Pre-fail Always - 9829 4 Start_Stop_Count 0x0032 099 099 000 Old_age Always - 1074 5 Reallocated_Sector_Ct 0x0033 252 252 010 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 252 252 051 Old_age Always - 0 8 Seek_Time_Performance 0x0024 252 252 015 Old_age Offline - 0 9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 19503 10 Spin_Retry_Count 0x0032 252 252 051 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 252 252 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 201 181 Program_Fail_Cnt_Total 0x0022 100 100 000 Old_age Always - 119446 191 G-Sense_Error_Rate 0x0022 100 100 000 Old_age Always - 2993 192 Power-Off_Retract_Count 0x0022 252 252 000 Old_age Always - 0 194 Temperature_Celsius 0x0002 064 059 000 Old_age Always - 24 (Min/Max 15/41) 195 Hardware_ECC_Recovered 0x003a 100 100 000 Old_age Always - 0 196 Reallocated_Event_Count 0x0032 252 252 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 252 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 252 252 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0036 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x002a 100 100 000 Old_age Always - 45 223 Load_Retry_Count 0x0032 252 252 000 Old_age Always - 0 225 Load_Cycle_Count 0x0032 052 052 000 Old_age Always - 491012
