I'm in the process of setting up my FreeNAS system with FreeNAS 8.0.1 Beta 4 and as I am using Samsung HD204UI drives, I read a lot about 4k sectors here in the forum.
Most of the discussion is about a better performance, which is true. With 4k sectors enabled, I do have about 20% better read&write performance.
But I noticed that my raidz1 volume (4x 2TB) with 4k sectors is smaller than without 4k enabled!
To verify this I created the volume with 4k sectors via the web GUI and manually from command line. Both tests resulted in a significant small volume.
Reported in the GUI:
Without 4k sectors: 5.3TB
With 4k sectors 5.2TB
The numbers above are from freshly created volumes (WebGUI with default settings).
As we are speaking of TBs here, this difference is huge ~ 157 GB less storage with 4k sectors enabled!
Can anyone explain please what is going on here? And how to fix this?![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
P.S.: Yes, the HDDs are patched :D
Filesystem 1K-blocks Used Avail Capacity Mounted on volume1 5732278193 31 5732278162 0% /mnt/volume1
Filesystem 1K-blocks Used Avail Capacity Mounted on volume1 5567643281 162 5567643119 0% /mnt/volume1
