Launch docker not exposing ports to node
radomirpolach
When I launch docker image and setup ports, I cannot access the application on the ports specified, it only works when I assign dedicated IP address to a pod.
I can't even access the application on the local IP:
$ sudo k3s kubectl get services -n ix-alpha
NAME              TYPE       CLUSTER-IP      EXTERNAL-IP   PORT(S)         AGE
alpha-ix-chart   NodePort   172.17.213.61   <none>        9093:9093/TCP   36s
$ curl http://172.17.213.61:9093
curl: (7) Failed to connect to 172.17.213.61 port 9093: No route to host
radomirpolach
The issue seems to be related to the fact that I can't internally access apps running in dockers.
When I expose the app above to for example 10.0.0.100, I can access it as 10.0.0.100:9093, but I can't do that from within the TrueNAS.
$ curl http://10.0.0.100:9093
curl: (7) Failed to connect to 10.0.0.100 port 9093: No route to host
radomirpolach
Ok, for this to work, you need to "Provide access to node network" and disable rolling update.
How and where is that done?
In a previous version of the official charts there was an option to adjust the container update policy (rolling update was one of the options)... no longer available a year later, so forget that bit.
For the other part, I assume you can see the checkbox labeled as indicated in the post above when creating a new app configuration.
