ChiknNutz
- Nov 6, 2015
I updated to the latest: FreeNAS-9.3-STABLE-201511280648. The last few updates have went totally fine. The file is shown below and gives a hint of what might work it says, but not really sure how to go about that. I also performed a "Verify Install" in the GUI and it fails the checksum. Should I just revert back to the previous build?
FATAL ERROR - The following SQL query failed: ALTER TABLE "services_fiberchannel totarget" RENAME TO "services_fibrechanneltotarget";
The error was: no such table: services_fiberchanneltotarget
Running migrations for api:
- Nothing to migrate.
- Loading initial data for api.
Installed 0 object(s) from 0 fixture(s)
Running migrations for freeadmin:
- Loading initial data for freeadmin.
Running migrations for support:
- Loading initial data for support.
Running migrations for vcp:
- Loading initial data for vcp.
Running migrations for jails:
- Loading initial data for jails.
Running migrations for directoryservice:
- Migrating forwards to 0054_auto__add_field_activedirectory_ad_allow_dns_updat es.
> directoryservice:0054_auto__add_field_activedirectory_ad_allow_dns_updates
- Loading initial data for directoryservice.
Running migrations for storage:
- Loading initial data for storage.
Running migrations for tasks:
- Loading initial data for tasks.
Running migrations for system:
- Migrating forwards to 0099_email_pwenc.
> system:0099_email_pwenc
- Migration 'system:0099_email_pwenc' is marked for no-dry-run.
- Loading initial data for system.
Running migrations for services:
- Migrating forwards to 0184_auto__del_fiberchanneltotarget__add_fibrechannelto target.
> services:0184_auto__del_fiberchanneltotarget__add_fibrechanneltotarget
! Error found during real run of migration! Aborting.
! Since you have a database that does not support running
! schema-altering statements in transactions, we have had
! to leave it in an interim state between migrations.
! You *might* be able to recover with: = ALTER TABLE "services_fibrechanneltot arget" RENAME TO "services_fiberchanneltotarget"; []
! The South developers regret this has happened, and would
! like to gently persuade you to consider a slightly
! easier-to-deal-with DBMS (one that supports DDL transactions)
! NOTE: The error which caused the migration to fail is further up.
Error in migration: services:0184_auto__del_fiberchanneltotarget__add_fibrechann eltotarget
File "/usr/local/www/freenasUI/manage.py", line 42, in <module>
execute_from_command_line(sys.argv)
File "/usr/local/lib/python2.7/site-packages/django/core/management/__init__.p y", line 399, in execute_from_command_line
utility.execute()
File "/usr/local/lib/python2.7/site-packages/django/core/management/__init__.p y", line 392, in execute
self.fetch_command(subcommand).run_from_argv(self.argv)
File "/usr/local/lib/python2.7/site-packages/django/core/management/base.py", line 242, in run_from_argv
self.execute(*args, **options.__dict__)
File "/usr/local/lib/python2.7/site-packages/django/core/management/base.py", line 285, in execute
output = self.handle(*args, **options)
File "/usr/local/lib/python2.7/site-packages/south/management/commands/migrate .py", line 111, in handle
ignore_ghosts = ignore_ghosts,
File "/usr/local/lib/python2.7/site-packages/south/migration/__init__.py", lin e 220, in migrate_app
success = migrator.migrate_many(target, workplan, database)
File "/usr/local/lib/python2.7/site-packages/south/migration/migrators.py", li ne 256, in migrate_many
result = migrator.__class__.migrate_many(migrator, target, migrations, datab ase)
File "/usr/local/lib/python2.7/site-packages/south/migration/migrators.py", li ne 331, in migrate_many
result = self.migrate(migration, database)
File "/usr/local/lib/python2.7/site-packages/south/migration/migrators.py", li ne 133, in migrate
result = self.run(migration, database)
File "/usr/local/lib/python2.7/site-packages/south/migration/migrators.py", li ne 114, in run
return self.run_migration(migration, database)
File "/usr/local/lib/python2.7/site-packages/south/migration/migrators.py", li ne 84, in run_migration
migration_function()
File "/usr/local/lib/python2.7/site-packages/south/migration/migrators.py", li ne 60, in <lambda>
return (lambda: direction(orm))
File "/usr/local/www/freenasUI/../freenasUI/services/migrations/0184_auto__del _fiberchanneltotarget__add_fibrechanneltotarget.py", line 11, in forwards
db.rename_table(u'services_fiberchanneltotarget', u'services_fibrechanneltot arget')
File "/usr/local/lib/python2.7/site-packages/south/db/generic.py", line 47, in _cache_clear
return func(self, table, *args, **opts)
File "/usr/local/lib/python2.7/site-packages/south/db/generic.py", line 375, i n rename_table
self.execute(self.rename_table_sql % params)
File "/usr/local/lib/python2.7/site-packages/south/db/generic.py", line 282, i n execute
cursor.execute(sql, params)
File "/usr/local/lib/python2.7/site-packages/django/db/backends/util.py", line 53, in execute
return self.cursor.execute(sql, params)
File "/usr/local/lib/python2.7/site-packages/django/db/utils.py", line 99, in __exit__
six.reraise(dj_exc_type, dj_exc_value, traceback)
File "/usr/local/www/freenasUI/../freenasUI/freeadmin/sqlite3_ha/base.py", lin e 386, in execute
return Database.Cursor.execute(self, query, params)
django.db.utils.OperationalError: no such table: services_fiberchanneltotarget
[root@AdcNAS] /data# cat update.failed
FATAL ERROR - The following SQL query failed: ALTER TABLE "services_fiberchanneltotarget" RENAME TO "services_fibrechanneltotarget";
- Migrating forwards to 0054_auto__add_field_activedirectory_ad_allow_dns_updates.
- Migrating forwards to 0184_auto__del_fiberchanneltotarget__add_fibrechanneltotarget.
! You *might* be able to recover with: = ALTER TABLE "services_fibrechanneltotarget" RENAME TO "services_fiberchanneltotarget"; []
Error in migration: services:0184_auto__del_fiberchanneltotarget__add_fibrechanneltotarget
File "/usr/local/lib/python2.7/site-packages/django/core/management/__init__.py", line 399, in execute_from_command_line
utility.execute()
File "/usr/local/lib/python2.7/site-packages/django/core/management/__init__.py", line 392, in execute
File "/usr/local/lib/python2.7/site-packages/south/management/commands/migrate.py", line 111, in handle
File "/usr/local/lib/python2.7/site-packages/south/migration/__init__.py", line 220, in migrate_app
File "/usr/local/lib/python2.7/site-packages/south/migration/migrators.py", line 256, in migrate_many
result = migrator.__class__.migrate_many(migrator, target, migrations, database)
File "/usr/local/lib/python2.7/site-packages/south/migration/migrators.py", line 331, in migrate_many
File "/usr/local/lib/python2.7/site-packages/south/migration/migrators.py", line 133, in migrate
File "/usr/local/lib/python2.7/site-packages/south/migration/migrators.py", line 114, in run
File "/usr/local/lib/python2.7/site-packages/south/migration/migrators.py", line 84, in run_migration
File "/usr/local/lib/python2.7/site-packages/south/migration/migrators.py", line 60, in <lambda>
File "/usr/local/www/freenasUI/../freenasUI/services/migrations/0184_auto__del_fiberchanneltotarget__add_fibrechanneltotarget.py", line 11, in forwards
db.rename_table(u'services_fiberchanneltotarget', u'services_fibrechanneltotarget')
File "/usr/local/lib/python2.7/site-packages/south/db/generic.py", line 375, in rename_table
File "/usr/local/lib/python2.7/site-packages/south/db/generic.py", line 282, in execute
File "/usr/local/www/freenasUI/../freenasUI/freeadmin/sqlite3_ha/base.py", line 386, in execute
